Are hash mismatches a problem? I get these 4 on diagnose and remain after running repair.
sudo swupd diagnose
Diagnosing version 42110
Downloading missing manifests…
Checking for missing files
[100%]
Checking for corrupt files
→ Hash mismatch for file: /usr/lib/modules/6.10.2-1454.native/modules.alias
→ Hash mismatch for file: /usr/lib/modules/6.10.2-1454.native/modules.alias.bin
→ Hash mismatch for file: /usr/lib/modules/6.10.2-1454.native/modules.dep
→ Hash mismatch for file: /usr/lib/modules/6.10.2-1454.native/modules.dep.bin
[100%]
Checking for extraneous files
[100%]
Inspected 289278 files
4 files did not match
Use “swupd repair” to correct the problems in the system
Diagnose successful
sudo swupd repair
[100%]
Validate downloaded files
[100%]
Starting download of remaining update content. This may take a while (6 files)…
[100%]
Adding any missing files
[100%]
Repairing corrupt files
→ Hash mismatch for file: /usr/lib/modules/6.10.2-1454.native/modules.alias → fixed
→ Hash mismatch for file: /usr/lib/modules/6.10.2-1454.native/modules.alias.bin → fixed
→ Hash mismatch for file: /usr/lib/modules/6.10.2-1454.native/modules.dep → fixed
→ Hash mismatch for file: /usr/lib/modules/6.10.2-1454.native/modules.dep.bin → fixed
[100%]
Removing extraneous files
[100%]
4 of 4 files were repaired
0 of 4 files were not repaired
External command: none
External command: Warning: The kernel is still using the old partition table.
External command: The new table will be used at the next reboot or after you
External command: run partprobe(8) or kpartx(8)
External command: The operation has completed successfully.
Repair successful
sudo swupd diagnose
[100%]
[100%]
[100%]
Diagnose successful
