p_m
1
Hi, I’m using external kernel module for wi-fi but after update to CL version 30500 with 5.2.2 kernel I got following error:
cc1: error: incompatible gcc/plugin versions
cc1: error: fail to initialize plugin ./scripts/gcc-plugins/structleak_plugin.so
Have a look at this GitHub issue:
The fix is already in our internal infra, it will be public in 1 or 2 days
p_m
4
Ok, thank you, I’ll wait for update.
The update is already available, please try again.
p_m
6
Yes, I already installed it, it’s fine now. wl driver compiles without error. Thank you.
