On the Gnome UI setting, the UI can detect my Lexmark printer after scanning the local network. The UI lists three names: JetDirect-Printer, LPD-Printer and Lexmark-MC3200. After choosing the Lexmark-MC3200, a new window appeared and showed: “Failed add new printer.”
Then, I download the driver from Lexmark MC3224dwe. and extract the rpm file using rpm2cpio ~/Lexmark-AEY-PPD-Files-1.0-06182019.x86_64 | cpio -idmv
The I run lpadmin -p Lexmark_MC3224dwe -v socket://xx.xx.x.xx -P /home/user/Downloads/usr/local/Lexmark/ppd/Lexmark-AEY-PPD-Files/GlobalPPD_1.4/Lexmark_MC3200_Series.ppd
. Then, a new printer entry appears on the Gnome printer setting.
However, the status is stopped. and triggering a print test doesn’t trigger the printer.
This is the output of journalctl -u cupsd
Jan 01 20:43:50 2in1clear cupsd[638]: REQUEST localhost - - "POST /admin/ HTTP/1.1" 401 136966 CUPS-Add-Modify-Printer successful-ok
Jan 01 20:43:50 2in1clear cupsd[638]: CreateProfile failed: org.freedesktop.ColorManager.AlreadyExists:profile id 'Lexmark_MC3224dwe-Gray..' already exists
Jan 01 20:43:50 2in1clear cupsd[638]: CreateProfile failed: org.freedesktop.ColorManager.AlreadyExists:profile id 'Lexmark_MC3224dwe-CMYK..' already exists
Jan 01 20:43:50 2in1clear cupsd[638]: REQUEST localhost - root "POST /admin/ HTTP/1.1" 200 136966 CUPS-Add-Modify-Printer successful-ok
Jan 01 20:44:24 2in1clear cupsd[638]: [Client 112] Returning IPP server-error-not-accepting-jobs for Print-Job (ipp://localhost:631/printers/Lexmark_MC3224dwe) from localhost.
Jan 01 20:44:24 2in1clear cupsd[638]: REQUEST localhost - - "POST /printers/Lexmark_MC3224dwe HTTP/1.1" 200 86607 Print-Job server-error-not-accepting-jobs
How can I fix this ipp job error?
Thanks in advance!
