Clear Linux says "Kernel Panic"
I use a laptop with amd ryzen laptop and radeon gpu. When I try to boot from usb it says Kernel panic. I can’t boot to clear linux or download it to my pc. I both tried Desktop iso and Server iso I have the same problem on both.
Like this?
Exactly like that. Same problem.
I’m not confident if this will fix this issue but did u give a try to this
You gotta use the last known working release instead of the auto release link, it’ll update to latest once it’s installed.
