Please can someone advise how to install dart & flutter on clear linux. I am new to clear linux and it flatpak sandbox and i would like to know how to go about installing the software as well as VS Code outside the flatpak sandbox.
The Dart SDK is bundled with Flutter; it is not necessary to install Dart separately.
mkdir flutter
cd flutter
wget https://storage.googleapis.com/flutter_infra/releases/stable/linux/flutter_linux_v1.7.8+hotfix.4-stable.tar.xz
tar xf flutter_linux_v1.7.8+hotfix.4-stable.tar.xz
Add the flutter tool to your path:
export PATH="$PATH:`pwd`/flutter/bin"
This command sets your PATH variable for the current terminal window only.
Flutter SDK
To set up flutter you need to install a gzip binary as clear uses pigz as an alias for this which causes issues with the pub command due to the streaming requirement.
To work around this issue I simply grabbed the http://ftp.gnu.org/gnu/gzip/gzip-1.10.tar.gz source and built it via the usual ./configure and make commands (NOTE no need to make install) simply grab the gzip binary and put it somewhere âcommonâ I moved it to my $HOME/.bin folder. Then throw this dir in front of your current path (export PATH=$HOME/.bin:$PATH) Then you should be able to simply git clone https://github.com/flutter/flutter.git (or download as per steps 1 & 2 of the install instructions) and follow step 3+ of the instructions at Linux install | Flutter.
Android SDK
To start with I installed: kvm-host, java-basic as java 8 and kvm are required to run the sdk tools & emulator. (dont forget to add yourself to the kvm group!)
Now this is where it gets hairy⌠(TLDR donât install your IDE using flatpak as it looks like is your desire - smart! but im not sure how to install vscode but it looks as though they provide a deb, rpm and tar.gz option so I imagine unzipping the tgz version might be all you need)
As I mostly do java work, I naviely installed Intellij IDEA through the package manager (this is then installed via flatpak much like vscode I imagine).
With the android plugin this made installing the android SDK a breeze but alas 2 issues had to be tracked down.
a) â/dev/kvmâ was being reported as not available preventing me from starting (but not creating) an android device image. To rectify this I need to update the applications .desktop file as such:
bjc@bjc-xps~ $ cat .local/share/flatpak/exports/share/applications/com.jetbrains.IntelliJ-IDEA-Community.desktop
[Desktop Entry]
Categories=Development;IDE;
Exec=/usr/bin/flatpak run --branch=stable --arch=x86_64 --device=kvm --command=idea com.jetbrains.IntelliJ-IDEA-Community
GenericName=Capable and Ergonomic Java IDE
Icon=com.jetbrains.IntelliJ-IDEA-Community
Keywords=development;idea;intellij;java;
Name=IntelliJ IDEA Community
StartupNotify=true
StartupWMClass=jetbrains-idea-ce
Terminal=false
Type=Application
X-Flatpak=com.jetbrains.IntelliJ-IDEA-Community```
Specifically I added the --device=kvm option.
b) Because Intellij was installed using flatpak (and now comes with java 11) I needed to install the âopenjdk 8 sdk extensionâ (this might be intellij specific) also note there are 2 of them with the same name and only 1 of them seems to expose the sdk correctly to intellji at /usr/lib/sdk/openjdk8/jvm/java-8-openjdk). Now the down side to this is that the certificate stores are not correctly exposed via flatpak (h ttps://github.com/flathub/org.freedesktop.Sdk.Extension.openjdk10/issues/4).
So I had to seed my projects outside of intellij (simply running ./gradlew build) in the âandroidâ dir of a flutter project will downloaded gradle & required dependencies which avoids the java ssl issues from intellij.
From here I was able to develop/debug my flutter app from within intellj.
Hope this helps or at least can be amended for vscode.
Hi guys⌠I have had trouble getting it to workâŚi have intellij installed but the config doesnât save as it canât create the desktop config⌠And also I managed to install Gradle, Maven and Java 11 with SDKman⌠Now I am having trouble opening the file explorer nautilus by default without running the command⌠And flutter has been giving trouble too so I deleted it. . Will re-install it using SDKman and please can you advise the directory of SDKman and itâs installed packages directory on clear linux⌠I am using the root account and cannot find it as easily as how ubuntu users find it.
Hey Sorry Its taken so long to get back to this. @EbieCAS. Iâm not sure what you are referring to with regards to the âconfig doesnât saveâ. I know its been a while so perhaps you have already solved this?
