thank you in advance
Is any one able to use Davinci-resolve in Clear Linux with an AMD (hybrid) graphic card ?
did it work with you ? I tried to install with NVIDIA and it is crashing when I try to add the media directory in settings.
The trick is to start resolve with sudo. Then everything works out of the box!! I might installed it with sudo as well, don’t remember.
Start with:
sudo /opt/resolve/bin/resolve
Version 17.2
Works extremly well and fluid. This with nvidia RTX2070. Never got it so lag free on any other os
