Hello everyone!
So I’m thinking about CL as my os to learn coding in python, C++ etc. Is it possible? Sorry if it’s a dumb question.
The reason behind considering CL is its blazing fast boot time.
Please share your thoughts.
Thank you.
Hello everyone!
Thank you.
Hi Nadim,
this is possible!
For C/C++ you should add the c-basic bundle.
For Python the python-basic bundle should get you started.
If you have no previous experience with Linux, you’d spend sometime struggling with setting up a workflow before you can learn anything. If it’s just for learning the programming language, you can use any OS.
