Hi, everyone! I have been usling OSK a lot and recently found that prediction fearure found in the OnScreen Keyboard shows the password as I type first 3 characters of the password!
I believe it is a security issue. How to completly disable the prediction? It is harmful even if trying to enter the password with numbers 1-6 - it will suggest 6 rusults and do the choice for you just because the password contains numbers.
Disable typing booster osk Gnome 43 is likely impossible without switching off the screen keyboard itself.
Edit: Though installing Improved OSK extension solves that behaivor! A new version is released!
https://extensions.gnome.org/extension/4413/improved-osk/
