Disk capacity requirements
Perhaps the docs should be note that even 34G won’t be enough if you go with the GUI and few extra packages. The docs advise 16-20 GB.
After first boot and 30+ minutes of waiting on swupd, I hit disk full and decided to wipe and start over rather than spend another 30 mins trying to recover.
Jun 05 02:27:05 clr-b7660840593141bb82b831358da5a37a swupd[476]: Error: Curl - Check free space for /var/lib/swupd?
Jun 05 02:27:05 clr-b7660840593141bb82b831358da5a37a swupd[476]: Warning: Write failed
Jun 05 02:27:05 clr-b7660840593141bb82b831358da5a37a swupd[476]: Warning: No space left on device
Jun 05 02:27:05 clr-b7660840593141bb82b831358da5a37a swupd[476]: Error: Curl - Error downloading to local file - 'https://cdn.download.clearlinux.org/update/36230/files/1c990cd11c5258ffac6e60eaf8c73d92af5d5829ef>
Jun 05 02:27:06 clr-b7660840593141bb82b831358da5a37a swupd[476]: Error: File content hash mismatch for /var/lib/swupd/staged/eabb7bf7ccbde051185401975c253f46891b9c2d014eb3bf7462886bb0013633 (bad server data?)
Jun 05 02:27:06 clr-b7660840593141bb82b831358da5a37a systemd[1]: swupd-update.service: Main process exited, code=exited, status=1/FAILURE
Jun 05 02:27:06 clr-b7660840593141bb82b831358da5a37a systemd[1]: swupd-update.service: Failed with result 'exit-code'.
Jun 05 02:27:06 clr-b7660840593141bb82b831358da5a37a systemd[1]: Failed to start Update Software content.
user@clr-b7660840593141bb82b831358da5a37a~ $ df -H
Filesystem      Size  Used Avail Use% Mounted on
/dev/root        34G   34G     0 100% /
devtmpfs        2.1G     0  2.1G   0% /dev
tmpfs           2.1G     0  2.1G   0% /dev/shm
tmpfs           822M  1.3M  821M   1% /run
tmpfs           4.2M     0  4.2M   0% /sys/fs/cgroup
tmpfs           2.1G  8.2k  2.1G   1% /tmp
