Gnome gui can not connect to openvpn
Hi, some tine ago everything was fine, but for now systemctl status NetworkManager gives the error:
ERROR: could not read Auth username/password/ok/string from management interface
Thus Network Manager not connecting to openvpn becouse cannot read username stored as a separate file under –auth-user-pass option in the config.ovpn.
Running the cli with sudo: sudo openvpn config.ovpn works fine.
P.S Trying #script-security option under config.ovpn with no luck for now.
