Since updating to 37560 version, gnome-keyring-deamon uses 100% of the CPU.
I must kill the daemon to slow down the fans or even to stop them.
Has anyone encountered this issue?
See below a screenshot.
My PC
Intel® Core™ i3-10105 CPU @ 3.70GHz × 8
Mesa Intel® UHD Graphics 630 (CML GT2)
nvme 512 GB
RAM 8
Hello
I notice you are not under 37560 version of clearlinux.
Before updating, there was no problem.
The issue is resolved in CL 37590.
Many thanks for your quick answer.
I’m going to update, but now I also need to update the nvidia driver as well !!!
There is another problem with the update, cmake asks for a 32 bits library which is not installed.
See below the screenshot.
You can’t use the terminal directly in a folder anymore. The update requires the console. Grrrrrrrr!!
To switch a session to another takes time.
Thanks for your help.
Marie
