mkdir ~/patched_source
git clone https://github.com/clearlinux-pkgs/linux ~/clearlinux_patches
cd ~/clearlinux_patches
./scripts/develop.sh ~/patched_source
it got stuck at
android@clr:~/clearlinux_patches/scripts (master)
$ ./develop.sh ~/patched_source
grep: /home/android/patched_source: Is a directory
It looks like you’re missing a parameter:
There is documentation on doing this manually here:
https://docs.01.org/clearlinux/latest/guides/kernel/kernel-development.html
@miguelinux should this script be added to the documentation above?
ahkok
3
You may want to use the common
tooling - GitHub - clearlinux/common: Developer tooling framework - it allows you to rebuild packages by just typing make
