pceiley
September 30, 2019, 10:49am
1
I’ve adapted the AUR PKGBUILD for hplip-plugin to install the hplip binary plugins on Clear Linux. This is required for a number of HP’s printers - especially the LaserJet series.
See https://developers.hp.com/hp-linux-imaging-and-printing/binary_plugin.html for more information.
You can see/get the script here: scripts/install_hplip_plugin.sh at master · pceiley/scripts · GitHub
ahkok
September 30, 2019, 4:42pm
2
I see:
install -m644 plugin.spec "/usr/share/hplip/"
install -m644 hp_laserjet_*.fw.gz "/usr/share/hplip/data/firmware/"
install -m755 fax_marvell-"$_arch".so "/usr/share/hplip/fax/plugins/"
install -m755 hbpl1-"$_arch".so "/usr/share/hplip/prnt/plugins/"
install -m755 lj-"$_arch".so "/usr/share/hplip/prnt/plugins/"
install -m755 bb_*-"$_arch".so "/usr/share/hplip/scan/plugins/"
We should really get this stuff to go into /usr/local
and /etc/
instead.
Agreed. But I believe hplip relies on the files being at these locations…
ahkok
October 9, 2019, 4:41pm
4
The hplip core is open source, though, so, it can be modified to scan other folders for plugins.
cant scan. any idea on fix? using HP MFP 26a
Hi, team!
@pceiley i have install your script, but i am not sucess in instalation the HP Deskjet 4200.
