Hi marioroy,
Does CL not run Gnome by default? I am presuming it’s GNOME not KDE or other desktop environment?
Also in removing the desktop-autostart - would that prevent the desktop from loading? Or just the login GDM.
Under Xorg.0.log I get an error - Server aborting
[ 27.452] (--) Log file renamed from "/var/log/Xorg.pid-1042.log" to "/var/log/Xorg.0.log"
[ 27.455]
X.Org X Server 1.21.1.8
X Protocol Version 11, Revision 0
[ 27.455] Current Operating System: Linux clr-d89af4ff027f497ebb94587107d9cbf6 6.3.2-1312.native #1 SMP Thu May 11 07:41:29 PDT 2023 x86_64
[ 27.455] Kernel command line: initrd=\EFI\org.clearlinux\freestanding-00-early-ucode.cpio initrd=\EFI\org.clearlinux\freestanding-i915-firmware.cpio.xz root=PARTUUID=db75abda-fd40w
[ 27.455]
[ 27.455] Current version of pixman: 0.42.2
[ 27.455] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 27.455] Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 27.456] (==) Log file: "/var/log/Xorg.0.log", Time: Sun May 21 12:01:07 2023
[ 27.456] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 27.457] (==) No Layout section. Using the first Screen section.
[ 27.457] (==) No screen section available. Using defaults.
[ 27.457] (**) |-->Screen "Default Screen Section" (0)
[ 27.457] (**) | |-->Monitor "<default monitor>"
[ 27.457] (==) No monitor specified for screen "Default Screen Section".
Using a default monitor configuration.
[ 27.457] (==) Automatically adding devices
[ 27.458] (==) Automatically enabling devices
[ 27.458] (==) Automatically adding GPU devices
[ 27.458] (==) Automatically binding GPU devices
[ 27.458] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 27.458] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/TTF,
/usr/share/fonts/X11/OTF,
/usr/share/fonts/X11/Type1,
/usr/share/fonts/X11/100dpi,
/usr/share/fonts/X11/75dpi
[ 27.458] (==) ModulePath set to "/usr/lib64/xorg/modules"
[ 27.458] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[ 27.458] (II) Module ABI versions:
[ 27.458] X.Org ANSI C Emulation: 0.4
[ 27.458] X.Org Video Driver: 25.2
[ 27.458] X.Org XInput driver : 24.4
[ 27.458] X.Org Server Extension : 10.0
[ 27.459] (++) using VT number 2
[ 27.461] (II) systemd-logind: took control of session /org/freedesktop/login1/session/_32
[ 27.462] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 27.462] (II) Platform probe for /sys/devices/pci0000:00/0000:00:01.0/drm/card0
[ 27.463] (II) systemd-logind: got fd for /dev/dri/card0 226:0 fd 11 paused 0
[ 27.467] (--) PCI:*(0@0:1:0) 1af4:1050:1af4:1100 rev 1, Mem @ 0xc0000000/8388608, 0x800500000/16384, 0xc2053000/4096, BIOS @ 0x????????/131072
[ 27.467] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 27.467] (II) LoadModule: "glx"
[ 27.468] (II) Loading /usr/lib64/xorg/modules/extensions/libglx.so
[ 27.469] (II) Module glx: vendor="X.Org Foundation"
[ 27.469] compiled for 1.21.1.8, module version = 1.0.0
[ 27.469] ABI class: X.Org Server Extension, version 10.0
[ 27.470] (==) Matched modesetting as autoconfigured driver 0
[ 27.470] (==) Matched fbdev as autoconfigured driver 1
[ 27.470] (==) Matched vesa as autoconfigured driver 2
[ 27.470] (==) Assigned the driver to the xf86ConfigLayout
[ 27.470] (II) LoadModule: "modesetting"
[ 27.470] (II) Loading /usr/lib64/xorg/modules/drivers/modesetting_drv.so
[ 27.471] (II) Module modesetting: vendor="X.Org Foundation"
[ 27.471] compiled for 1.21.1.8, module version = 1.21.1
[ 27.471] Module class: X.Org Video Driver
[ 27.471] ABI class: X.Org Video Driver, version 25.2
[ 27.471] (II) LoadModule: "fbdev"
[ 27.471] (II) Loading /usr/lib64/xorg/modules/drivers/fbdev_drv.so
[ 27.471] (II) Module fbdev: vendor="X.Org Foundation"
[ 27.471] compiled for 1.21.1.8, module version = 0.5.0
[ 27.472] Module class: X.Org Video Driver
[ 27.472] ABI class: X.Org Video Driver, version 25.2
[ 27.472] (II) LoadModule: "vesa"
[ 27.472] (II) Loading /usr/lib64/xorg/modules/drivers/vesa_drv.so
[ 27.472] (II) Module vesa: vendor="X.Org Foundation"
[ 27.472] compiled for 1.21.1.8, module version = 2.6.0
[ 27.472] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 27.472] (II) FBDEV: driver for framebuffer: fbdev
[ 27.472] (II) VESA: driver for VESA chipsets: vesa
[ 27.473] (II) modeset(0): using drv /dev/dri/card0
[ 27.473] (WW) Falling back to old probe method for fbdev
[ 27.473] (II) Loading sub module "fbdevhw"
[ 27.473] (II) LoadModule: "fbdevhw"
[ 27.473] (II) Loading /usr/lib64/xorg/modules/libfbdevhw.so
[ 27.473] (II) Module fbdevhw: vendor="X.Org Foundation"
[ 27.473] compiled for 1.21.1.8, module version = 0.0.2
[ 27.473] ABI class: X.Org Video Driver, version 25.2
[ 27.473] (II) modeset(0): Creating default Display subsection in Screen section
"Default Screen Section" for depth/fbbpp 24/32
[ 27.473] (==) modeset(0): Depth 24, (==) framebuffer bpp 32
[ 27.474] (==) modeset(0): RGB weight 888
[ 27.474] (==) modeset(0): Default visual is TrueColor
[ 27.474] (II) Loading sub module "glamoregl"
[ 27.474] (II) LoadModule: "glamoregl"
[ 27.474] (II) Loading /usr/lib64/xorg/modules/libglamoregl.so
[ 27.476] (II) Module glamoregl: vendor="X.Org Foundation"
[ 27.476] compiled for 1.21.1.8, module version = 1.0.1
[ 27.477] ABI class: X.Org ANSI C Emulation, version 0.4
[ 27.504] (II) modeset(0): Refusing to try glamor on llvmpipe
[ 27.505] (II) modeset(0): glamor initialization failed
[ 27.505] (II) modeset(0): ShadowFB: preferred NO, enabled NO
[ 27.505] (II) modeset(0): Output Virtual-1 has no monitor section
[ 27.505] (II) modeset(0): EDID for output Virtual-1
[ 27.505] (II) modeset(0): Manufacturer: RHT Model: 1234 Serial#: 0
[ 27.505] (II) modeset(0): Year: 2014 Week: 42
[ 27.505] (II) modeset(0): EDID Version: 1.4
[ 27.505] (II) modeset(0): Digital Display Input
[ 27.506] (II) modeset(0): 8 bits per channel
[ 27.506] (II) modeset(0): Digital interface is DisplayPort
[ 27.506] (II) modeset(0): Max Image Size [cm]: horiz.: 32 vert.: 20
[ 27.506] (II) modeset(0): Gamma: 2.20
[ 27.506] (II) modeset(0): No DPMS capabilities specified
[ 27.506] (II) modeset(0): Supported color encodings: RGB 4:4:4
[ 27.506] (II) modeset(0): Default color space is primary color space
[ 27.506] (II) modeset(0): First detailed timing is preferred mode
[ 27.506] (II) modeset(0): Preferred mode is native pixel format and refresh rate
[ 27.506] (II) modeset(0): redX: 0.640 redY: 0.330 greenX: 0.300 greenY: 0.600
[ 27.506] (II) modeset(0): blueX: 0.150 blueY: 0.060 whiteX: 0.312 whiteY: 0.329
[ 27.506] (II) modeset(0): Supported established timings:
[ 27.506] (II) modeset(0): 640x480@60Hz
[ 27.506] (II) modeset(0): 800x600@60Hz
[ 27.506] (II) modeset(0): 1024x768@60Hz
[ 27.506] (II) modeset(0): Manufacturer's mask: 0
[ 27.506] (II) modeset(0): Supported standard timings:
[ 27.506] (II) modeset(0): #0: hsize: 2048 vsize 1152 refresh: 60 vid: 49377
[ 27.506] (II) modeset(0): #1: hsize: 1920 vsize 1080 refresh: 60 vid: 49361
[ 27.506] (II) modeset(0): #2: hsize: 1920 vsize 1200 refresh: 60 vid: 209
[ 27.506] (II) modeset(0): #3: hsize: 1600 vsize 1200 refresh: 60 vid: 16553
[ 27.506] (II) modeset(0): #4: hsize: 1680 vsize 1050 refresh: 60 vid: 179
[ 27.506] (II) modeset(0): #5: hsize: 1440 vsize 900 refresh: 60 vid: 149
[ 27.506] (II) modeset(0): #6: hsize: 1280 vsize 1024 refresh: 60 vid: 32897
[ 27.506] (II) modeset(0): #7: hsize: 1280 vsize 960 refresh: 60 vid: 16513
[ 27.506] (II) modeset(0): Supported detailed timing:
[ 27.506] (II) modeset(0): clock: 107.3 MHz Image Size: 325 x 203 mm
[ 27.506] (II) modeset(0): h_active: 1280 h_sync: 1600 h_sync_end 1638 h_blank_end 1728 h_border: 0
[ 27.506] (II) modeset(0): v_active: 800 v_sync: 804 v_sync_end 808 v_blanking: 828 v_border: 0
[ 27.507] (II) modeset(0): Established timings III: (not decoded)
[ 27.507] (II) modeset(0): Ranges: V min: 50 V max: 125 Hz, H min: 30 H max: 160 kHz,
[ 27.507] (II) modeset(0): Monitor name: QEMU Monitor
[ 27.507] (II) modeset(0): Number of EDID sections to follow: 1
[ 27.507] (II) modeset(0): EDID (in hex):
[ 27.507] (II) modeset(0): 00ffffffffffff004914341200000000
[ 27.507] (II) modeset(0): 2a180104a520147806ee91a3544c9926
[ 27.507] (II) modeset(0): 0f5054210800e1c0d1c0d100a940b300
[ 27.507] (II) modeset(0): 950081808140ea2900c051201c304026
[ 27.507] (II) modeset(0): 444045cb10000018000000f7000a0040
[ 27.507] (II) modeset(0): 82002820000000000000000000fd0032
[ 27.507] (II) modeset(0): 7d1ea0ff010a202020202020000000fc
[ 27.507] (II) modeset(0): 0051454d55204d6f6e69746f720a013a
[ 27.507] (II) modeset(0): 02030b00467d6560591f610000001000
[ 27.507] (II) modeset(0): 00000000000000000000000000000000
[ 27.507] (II) modeset(0): 10000000000000000000000000000000
[ 27.507] (II) modeset(0): 00001000000000000000000000000000
[ 27.507] (II) modeset(0): 00000000100000000000000000000000
[ 27.507] (II) modeset(0): 00000000000010000000000000000000
[ 27.507] (II) modeset(0): 00000000000000001000000000000000
[ 27.507] (II) modeset(0): 0000000000000000000000000000002f
[ 27.507] (II) modeset(0): Printing probed modes for output Virtual-1
[ 27.507] (II) modeset(0): Modeline "1280x800"x75.0 107.30 1280 1600 1638 1728 800 804 808 828 -hsync -vsync (62.1 kHz eP)
[ 27.507] (II) modeset(0): Modeline "5120x2160"x50.0 742.50 5120 6216 6304 6600 2160 2168 2178 2250 +hsync +vsync (112.5 kHz e)
[ 27.507] (II) modeset(0): Modeline "4096x2160"x50.0 594.00 4096 5064 5152 5280 2160 2168 2178 2250 +hsync +vsync (112.5 kHz e)
[ 27.507] (II) modeset(0): Modeline "3840x2160"x60.0 594.00 3840 4016 4104 4400 2160 2168 2178 2250 +hsync +vsync (135.0 kHz e)
[ 27.507] (II) modeset(0): Modeline "3840x2160"x50.0 594.00 3840 4896 4984 5280 2160 2168 2178 2250 +hsync +vsync (112.5 kHz e)
[ 27.507] (II) modeset(0): Modeline "3840x2160"x59.9 593.41 3840 4016 4104 4400 2160 2168 2178 2250 +hsync +vsync (134.9 kHz e)
[ 27.507] (II) modeset(0): Modeline "1920x1440"x60.0 234.00 1920 2048 2256 2600 1440 1441 1444 1500 -hsync +vsync (90.0 kHz e)
[ 27.507] (II) modeset(0): Modeline "2560x1080"x50.0 185.62 2560 3108 3152 3300 1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[ 27.507] (II) modeset(0): Modeline "1856x1392"x60.0 218.25 1856 1952 2176 2528 1392 1393 1396 1439 -hsync +vsync (86.3 kHz e)
[ 27.508] (II) modeset(0): Modeline "1792x1344"x60.0 204.75 1792 1920 2120 2448 1344 1345 1348 1394 -hsync +vsync (83.6 kHz e)
[ 27.508] (II) modeset(0): Modeline "2048x1152"x60.0 162.00 2048 2074 2154 2250 1152 1153 1156 1200 +hsync +vsync (72.0 kHz e)
[ 27.508] (II) modeset(0): Modeline "1920x1200"x59.9 193.25 1920 2056 2256 2592 1200 1203 1209 1245 -hsync +vsync (74.6 kHz e)
[ 27.508] (II) modeset(0): Modeline "1920x1080"x60.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 -hsync -vsync (67.5 kHz e)
[ 27.508] (II) modeset(0): Modeline "1920x1080"x50.0 148.50 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[ 27.508] (II) modeset(0): Modeline "1600x1200"x60.0 162.00 1600 1664 1856 2160 1200 1201 1204 1250 +hsync +vsync (75.0 kHz e)
[ 27.508] (II) modeset(0): Modeline "1680x1050"x60.0 146.25 1680 1784 1960 2240 1050 1053 1059 1089 -hsync +vsync (65.3 kHz e)
[ 27.508] (II) modeset(0): Modeline "1400x1050"x60.0 121.75 1400 1488 1632 1864 1050 1053 1057 1089 -hsync +vsync (65.3 kHz e)
[ 27.508] (II) modeset(0): Modeline "1280x1024"x60.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 27.508] (II) modeset(0): Modeline "1440x900"x59.9 106.50 1440 1520 1672 1904 900 903 909 934 -hsync +vsync (55.9 kHz e)
[ 27.508] (II) modeset(0): Modeline "1280x960"x60.0 108.00 1280 1376 1488 1800 960 961 964 1000 +hsync +vsync (60.0 kHz e)
[ 27.508] (II) modeset(0): Modeline "1360x768"x60.0 85.50 1360 1424 1536 1792 768 771 777 795 +hsync +vsync (47.7 kHz e)
[ 27.508] (II) modeset(0): Modeline "1280x768"x59.9 79.50 1280 1344 1472 1664 768 771 778 798 -hsync +vsync (47.8 kHz e)
[ 27.508] (II) modeset(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 27.508] (II) modeset(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 27.508] (II) modeset(0): Modeline "640x480"x60.0 25.20 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 27.508] (II) modeset(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 27.508] (II) modeset(0): Output Virtual-1 connected
[ 27.508] (II) modeset(0): Using exact sizes for initial modes
[ 27.508] (II) modeset(0): Output Virtual-1 using initial mode 1280x800 +0+0
[ 27.508] (==) modeset(0): Using gamma correction (1.0, 1.0, 1.0)
[ 27.508] (==) modeset(0): DPI set to (96, 96)
[ 27.508] (II) Loading sub module "fb"
[ 27.508] (II) LoadModule: "fb"
[ 27.508] (II) Module "fb" already built-in
[ 27.508] (II) UnloadModule: "fbdev"
[ 27.508] (II) Unloading fbdev
[ 27.508] (II) UnloadSubModule: "fbdevhw"
[ 27.509] (II) Unloading fbdevhw
[ 27.509] (II) UnloadModule: "vesa"
[ 27.509] (II) Unloading vesa
[ 27.510] (==) modeset(0): Backing store enabled
[ 27.510] (==) modeset(0): Silken mouse enabled
[ 27.510] (II) modeset(0): Initializing kms color map for depth 24, 8 bpc.
[ 27.511] (==) modeset(0): DPMS enabled
[ 27.511] (II) Initializing extension Generic Event Extension
[ 27.511] (II) Initializing extension SHAPE
[ 27.511] (II) Initializing extension MIT-SHM
[ 27.511] (II) Initializing extension XInputExtension
[ 27.511] (II) Initializing extension XTEST
[ 27.511] (II) Initializing extension BIG-REQUESTS
[ 27.511] (II) Initializing extension SYNC
[ 27.511] (II) Initializing extension XKEYBOARD
[ 27.511] (II) Initializing extension XC-MISC
[ 27.511] (II) Initializing extension XFIXES
[ 27.511] (II) Initializing extension RENDER
[ 27.511] (II) Initializing extension RANDR
[ 27.511] (II) Initializing extension COMPOSITE
[ 27.511] (II) Initializing extension DAMAGE
[ 27.511] (II) Initializing extension MIT-SCREEN-SAVER
[ 27.511] (II) Initializing extension DOUBLE-BUFFER
[ 27.511] (II) Initializing extension RECORD
[ 27.511] (II) Initializing extension DPMS
[ 27.512] (II) Initializing extension Present
[ 27.512] (II) Initializing extension DRI3
[ 27.512] (II) Initializing extension X-Resource
[ 27.512] (II) Initializing extension XVideo
[ 27.512] (II) Initializing extension XVideo-MotionCompensation
[ 27.512] (II) Initializing extension GLX
[ 27.512] (II) AIGLX: Screen 0 is not DRI2 capable
[ 27.516] (II) IGLX: Loaded and initialized swrast
[ 27.516] (II) GLX: Initialized DRISWRAST GL provider for screen 0
[ 27.516] (II) Initializing extension XFree86-VidModeExtension
[ 27.517] (II) Initializing extension XFree86-DGA
[ 27.517] (II) Initializing extension XFree86-DRI
[ 27.517] (II) Initializing extension DRI2
[ 27.517] (II) modeset(0): Damage tracking initialized
[ 27.517] (II) modeset(0): Setting screen physical size to 338 x 211
[ 27.554] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[ 27.554] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 27.554] (II) LoadModule: "libinput"
[ 27.554] (II) Loading /usr/lib64/xorg/modules/input/libinput_drv.so
[ 27.555] (II) Module libinput: vendor="X.Org Foundation"
[ 27.555] compiled for 1.21.1.8, module version = 1.3.0
[ 27.555] Module class: X.Org XInput Driver
[ 27.555] ABI class: X.Org XInput driver, version 24.4
[ 27.555] (II) Using input driver 'libinput' for 'Power Button'
[ 27.556] (II) systemd-logind: got fd for /dev/input/event0 13:64 fd 22 paused 0
[ 27.556] (**) Power Button: always reports core events
[ 27.556] (**) Option "Device" "/dev/input/event0"
[ 27.557] (II) event0 - Power Button: is tagged by udev as: Keyboard
[ 27.557] (II) event0 - Power Button: device is a keyboard
[ 27.558] (II) event0 - Power Button: device removed
[ 27.558] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input0/event0"
[ 27.558] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[ 27.558] (II) event0 - Power Button: is tagged by udev as: Keyboard
[ 27.558] (II) event0 - Power Button: device is a keyboard
[ 27.559] (II) config/udev: Adding input device QEMU QEMU USB Tablet (/dev/input/event1)
[ 27.559] (**) QEMU QEMU USB Tablet: Applying InputClass "libinput pointer catchall"
[ 27.559] (II) Using input driver 'libinput' for 'QEMU QEMU USB Tablet'
[ 27.708] (II) systemd-logind: got fd for /dev/input/event1 13:65 fd 25 paused 0
[ 27.708] (**) QEMU QEMU USB Tablet: always reports core events
[ 27.708] (**) Option "Device" "/dev/input/event1"
[ 27.710] (II) event1 - QEMU QEMU USB Tablet: is tagged by udev as: Mouse
[ 27.710] (II) event1 - QEMU QEMU USB Tablet: device is a pointer
[ 27.710] (II) event1 - QEMU QEMU USB Tablet: device removed
[ 27.711] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:02.1/0000:02:00.0/usb1/1-1/1-1:1.0/0003:0627:0001.0001/input/input1/event1"
[ 27.711] (II) XINPUT: Adding extended input device "QEMU QEMU USB Tablet" (type: MOUSE, id 7)
[ 27.711] (**) Option "AccelerationScheme" "none"
[ 27.711] (**) QEMU QEMU USB Tablet: (accel) selected scheme none/0
[ 27.711] (**) QEMU QEMU USB Tablet: (accel) acceleration factor: 2.000
[ 27.711] (**) QEMU QEMU USB Tablet: (accel) acceleration threshold: 4
[ 27.712] (II) event1 - QEMU QEMU USB Tablet: is tagged by udev as: Mouse
[ 27.712] (II) event1 - QEMU QEMU USB Tablet: device is a pointer
[ 27.713] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event2)
[ 27.713] (**) AT Translated Set 2 keyboard: Applying InputClass "libinput keyboard catchall"
[ 27.713] (II) Using input driver 'libinput' for 'AT Translated Set 2 keyboard'
[ 27.714] (II) systemd-logind: got fd for /dev/input/event2 13:66 fd 26 paused 0
[ 27.714] (**) AT Translated Set 2 keyboard: always reports core events
[ 27.714] (**) Option "Device" "/dev/input/event2"
[ 27.716] (II) event2 - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[ 27.716] (II) event2 - AT Translated Set 2 keyboard: device is a keyboard
[ 27.716] (II) event2 - AT Translated Set 2 keyboard: device removed
[ 27.716] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input2/event2"
[ 27.717] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 8)
[ 27.717] (II) event2 - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[ 27.718] (II) event2 - AT Translated Set 2 keyboard: device is a keyboard
[ 27.719] (II) config/udev: Adding input device ImExPS/2 Generic Explorer Mouse (/dev/input/event3)
[ 27.719] (**) ImExPS/2 Generic Explorer Mouse: Applying InputClass "libinput pointer catchall"
[ 27.719] (II) Using input driver 'libinput' for 'ImExPS/2 Generic Explorer Mouse'
[ 27.720] (II) systemd-logind: got fd for /dev/input/event3 13:67 fd 27 paused 0
[ 27.720] (**) ImExPS/2 Generic Explorer Mouse: always reports core events
[ 27.720] (**) Option "Device" "/dev/input/event3"
[ 27.721] (II) event3 - ImExPS/2 Generic Explorer Mouse: is tagged by udev as: Mouse
[ 27.722] (II) event3 - ImExPS/2 Generic Explorer Mouse: device is a pointer
[ 27.723] (II) event3 - ImExPS/2 Generic Explorer Mouse: device removed
[ 27.723] (II) libinput: ImExPS/2 Generic Explorer Mouse: Step value 0 was provided, libinput Fallback acceleration function is used.
[ 27.724] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio1/input/input4/event3"
[ 27.724] (II) XINPUT: Adding extended input device "ImExPS/2 Generic Explorer Mouse" (type: MOUSE, id 9)
[ 27.725] (**) Option "AccelerationScheme" "none"
[ 27.725] (**) ImExPS/2 Generic Explorer Mouse: (accel) selected scheme none/0
[ 27.725] (**) ImExPS/2 Generic Explorer Mouse: (accel) acceleration factor: 2.000
[ 27.725] (**) ImExPS/2 Generic Explorer Mouse: (accel) acceleration threshold: 4
[ 27.726] (II) event3 - ImExPS/2 Generic Explorer Mouse: is tagged by udev as: Mouse
[ 27.726] (II) event3 - ImExPS/2 Generic Explorer Mouse: device is a pointer
[ 28.134] (II) modeset(0): EDID vendor "RHT", prod id 4660
[ 28.134] (II) modeset(0): Using EDID range info for horizontal sync
[ 28.134] (II) modeset(0): Using EDID range info for vertical refresh
[ 28.134] (II) modeset(0): Printing DDC gathered Modelines:
[ 28.134] (II) modeset(0): Modeline "1280x800"x0.0 107.30 1280 1600 1638 1728 800 804 808 828 -hsync -vsync (62.1 kHz eP)
[ 28.134] (II) modeset(0): Modeline "1280x768"x0.0 79.50 1280 1344 1472 1664 768 771 778 798 -hsync +vsync (47.8 kHz e)
[ 28.134] (II) modeset(0): Modeline "1360x768"x0.0 85.50 1360 1424 1536 1792 768 771 777 795 +hsync +vsync (47.7 kHz e)
[ 28.134] (II) modeset(0): Modeline "1400x1050"x0.0 121.75 1400 1488 1632 1864 1050 1053 1057 1089 -hsync +vsync (65.3 kHz e)
[ 28.134] (II) modeset(0): Modeline "1792x1344"x0.0 204.75 1792 1920 2120 2448 1344 1345 1348 1394 -hsync +vsync (83.6 kHz e)
[ 28.134] (II) modeset(0): Modeline "1856x1392"x0.0 218.25 1856 1952 2176 2528 1392 1393 1396 1439 -hsync +vsync (86.3 kHz e)
[ 28.134] (II) modeset(0): Modeline "1920x1440"x0.0 234.00 1920 2048 2256 2600 1440 1441 1444 1500 -hsync +vsync (90.0 kHz e)
[ 28.134] (II) modeset(0): Modeline "1920x1080"x0.0 148.50 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[ 28.134] (II) modeset(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 28.134] (II) modeset(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 28.134] (II) modeset(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 28.134] (II) modeset(0): Modeline "2048x1152"x60.0 197.97 2048 2184 2408 2768 1152 1153 1156 1192 -hsync +vsync (71.5 kHz e)
[ 28.134] (II) modeset(0): Modeline "1920x1080"x60.0 172.80 1920 2040 2248 2576 1080 1081 1084 1118 -hsync +vsync (67.1 kHz e)
[ 28.134] (II) modeset(0): Modeline "1920x1200"x0.0 193.25 1920 2056 2256 2592 1200 1203 1209 1245 -hsync +vsync (74.6 kHz e)
[ 28.134] (II) modeset(0): Modeline "1600x1200"x0.0 162.00 1600 1664 1856 2160 1200 1201 1204 1250 +hsync +vsync (75.0 kHz e)
[ 28.134] (II) modeset(0): Modeline "1680x1050"x0.0 146.25 1680 1784 1960 2240 1050 1053 1059 1089 -hsync +vsync (65.3 kHz e)
[ 28.134] (II) modeset(0): Modeline "1440x900"x0.0 106.50 1440 1520 1672 1904 900 903 909 934 -hsync +vsync (55.9 kHz e)
[ 28.134] (II) modeset(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 28.134] (II) modeset(0): Modeline "1280x960"x0.0 108.00 1280 1376 1488 1800 960 961 964 1000 +hsync +vsync (60.0 kHz e)
[ 28.584] (EE)
[ 28.584] (EE) Backtrace:
[ 28.584] (EE) 0: /usr/bin/X (xorg_backtrace+0x47) [0x55a345069f27]
[ 28.584] (EE) 1: /usr/bin/X (0x55a344f05000+0x168df9) [0x55a34506ddf9]
[ 28.584] (EE) 2: /usr/lib64/glibc-hwcaps/x86-64-v3/libc.so.6 (0x55a344400000+0x3c6e0) [0x55a34443c6e0]
[ 28.584] (EE) 3: /usr/lib64/glibc-hwcaps/x86-64-v3/libc.so.6 (pthread_kill+0xfb) [0x55a3444928eb]
[ 28.584] (EE) 4: /usr/lib64/glibc-hwcaps/x86-64-v3/libc.so.6 (gsignal+0x12) [0x55a34443c642]
[ 28.584] (EE) 5: /usr/lib64/glibc-hwcaps/x86-64-v3/libc.so.6 (abort+0xc5) [0x55a34442249f]
[ 28.584] (EE) 6: /usr/lib64/glibc-hwcaps/x86-64-v3/libc.so.6 (0x55a344400000+0x223d5) [0x55a3444223d5]
[ 28.584] (EE) 7: /usr/lib64/glibc-hwcaps/x86-64-v3/libc.so.6 (0x55a344400000+0x33452) [0x55a344433452]
[ 28.584] (EE) 8: /usr/bin/X (0x55a344f05000+0x1faa73) [0x55a3450ffa73]
[ 28.584] (EE) 9: /usr/bin/X (0x55a344f05000+0x1fd2e6) [0x55a3451022e6]
[ 28.584] (EE) 10: /usr/bin/X (0x55a344f05000+0x1fdfbb) [0x55a345102fbb]
[ 28.584] (EE) 11: /usr/bin/X (0x55a344f05000+0x8167c) [0x55a344f8667c]
[ 28.584] (EE) 12: /usr/bin/X (0x55a344f05000+0x8641d) [0x55a344f8b41d]
[ 28.584] (EE) 13: /usr/lib64/glibc-hwcaps/x86-64-v3/libc.so.6 (0x55a344400000+0x238f7) [0x55a3444238f7]
[ 28.584] (EE) 14: /usr/lib64/glibc-hwcaps/x86-64-v3/libc.so.6 (__libc_start_main+0x85) [0x55a3444239b5]
[ 28.584] (EE) 15: /usr/bin/X (_start+0x21) [0x55a344f45991]
[ 28.584] (EE)
[ 28.584] (EE)
Fatal server error:
[ 28.584] (EE) Caught signal 6 (Aborted). Server aborting
[ 28.584] (EE)
[ 28.584] (EE)
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
[ 28.584] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
[ 28.584] (EE)
[ 28.588] (EE) Server terminated with error (1). Closing log file.
Anywhere else to look to troubleshoot?
