Intel Arc A750 & A770
Some time has gone by since I asked this question but will the Intel ARC 770 work with an AMD motherboard?
Will I be able to update Clear Linux Version without fear of making system in-operable?
My desire is to replace my current Nvidia graphics card with the Intel Arc 770 and have swupd updates
work without fear of making my system a brick? It’s is the main router and server in my house.
I have seen “Profile - marioroy - Clear Linux OS Forum” work:
GitHub - marioroy/nvidia-driver-on-clear-linux: NVIDIA driver installation on Clear Linux
It’s excellent from what I can tell, to be able to use an Nvidia graphics card with proprietary drivers, but
still be able to update both the Nvidia drivers and Clear Linux.
Also if I were to replace my Nvidia graphics card [GeForce GT 1030] will I have access to GPU development code/training for the Intel Arc 770 since Intel supports Clear Linux?
Information about my AMD system:
lsscpu
Architecture: x86_64
CPU op-mode(s): 32-bit, 64-bit
Address sizes: 48 bits physical, 48 bits virtual
Byte Order: Little Endian
CPU(s): 32
On-line CPU(s) list: 0-31
Vendor ID: AuthenticAMD
BIOS Vendor ID: Advanced Micro Devices, Inc.
Model name: AMD Ryzen 9 5950X 16-Core Processor
BIOS Model name: AMD Ryzen 9 5950X 16-Core Processor Unknown CPU @ 3.4GHz
BIOS CPU family: 107
CPU family: 25
Model: 33
Thread(s) per core: 2
Core(s) per socket: 16
Socket(s): 1
Stepping: 2
Frequency boost: enabled
CPU(s) scaling MHz: 68%
CPU max MHz: 5083.3979
CPU min MHz: 2200.0000
BogoMIPS: 6787.55
Flags: fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush mmx fxsr sse sse2 ht syscall nx mmxext fxsr_opt pdpe1gb rdtscp lm c
onstant_tsc rep_good nopl nonstop_tsc cpuid extd_apicid aperfmperf rapl pni pclmulqdq monitor ssse3 fma cx16 sse4_1 sse4_2 x2apic movbe popcnt aes
xsave avx f16c rdrand lahf_lm cmp_legacy svm extapic cr8_legacy abm sse4a misalignsse 3dnowprefetch osvw ibs skinit wdt tce topoext perfctr_core pe
rfctr_nb bpext perfctr_llc mwaitx cpb cat_l3 cdp_l3 hw_pstate ssbd mba ibrs ibpb stibp vmmcall fsgsbase bmi1 avx2 smep bmi2 erms invpcid cqm rdt_a
rdseed adx smap clflushopt clwb sha_ni xsaveopt xsavec xgetbv1 xsaves cqm_llc cqm_occup_llc cqm_mbm_total cqm_mbm_local clzero irperf xsaveerptr rd
pru wbnoinvd arat npt lbrv svm_lock nrip_save tsc_scale vmcb_clean flushbyasid decodeassists pausefilter pfthreshold avic v_vmsave_vmload vgif v_sp
ec_ctrl umip pku ospke vaes vpclmulqdq rdpid overflow_recov succor smca fsrm
Virtualization features:
Virtualization: AMD-V
Caches (sum of all):
L1d: 512 KiB (16 instances)
L1i: 512 KiB (16 instances)
L2: 8 MiB (16 instances)
L3: 64 MiB (2 instances)
NUMA:
NUMA node(s): 1
NUMA node0 CPU(s): 0-31
Vulnerabilities:
Itlb multihit: Not affected
L1tf: Not affected
Mds: Not affected
Meltdown: Not affected
Mmio stale data: Not affected
Retbleed: Not affected
Spec store bypass: Mitigation; Speculative Store Bypass disabled via prctl
Spectre v1: Mitigation; usercopy/swapgs barriers and __user pointer sanitization
Spectre v2: Mitigation; Retpolines, IBPB conditional, IBRS_FW, STIBP always-on, RSB filling, PBRSB-eIBRS Not affected
Srbds: Not affected
Tsx async abort: Not affected
