libboost_context.so missing while running yuzu emulator. i have installed runtime-libs-boost but still it says the file is missing.how can i get that ?
This file is installed. Where do you get the emulator?
the emu requires a older version 1.71.0 .it doesnt run with 1.73.0
Did you follow their guide to build it? Have you see any error?
Yes I followed the instructions.it gave me an error libboost_context 1.71.0 not found.
You can compile yuzu from the scratch:
Install Prerequisite
sudo swupd bundle-add qt-basic-dev devpkg-SDL2
sudo pip3 install conan
Install Pyenv (yuzu require python2 for compilation)
sudo swupd bundle-add devpkg-ncurses sqlite devpkg-openssl tcl-basic devpkg-readline devpkg-bzip2 devpkg-sqlite-autoconf devpkg-libffi devpkg-xz
curl -L https://github.com/pyenv/pyenv-installer/raw/master/bin/pyenv-installer | bash
~/.pyenv/bin/pyenv install 2.7.18
Clone yuzu
cd ~/Downloads
git clone --recursive https://github.com/yuzu-emu/yuzu
cd yuzu && mkdir build && cd build
Fix things to make it compiling
sed -i 's/Boost 1.71 COMPONENTS context headers REQUIRED/Boost 1.73.0 COMPONENTS context REQUIRED/' ../src/common/CMakeLists.txt
sed -i '/fvisibility=hidden/a UNICORN_QEMU_FLAGS += --python=/home/$(USERNAME)/.pyenv/versions/2.7.18/bin/python' ../externals/unicorn/Makefile
Finally make
cmake .. -GNinja
ninja
Now you can find yuzu in bin subfolder. It seems something else needed to do, but i have no idea what , just follow their guide.
Thanks will try it.you just need to dump keys from switch to run yuzu.i didn’t understand what you are trying to do when you say fixing compilation.also python 2 bundle is available on clearlinux .should I need to do the second step if I install that bundle?
Oh wow, i missed that python2 package exist lol. Thanks for pointing that!
Okay just tested , updated guide here:
sudo swupd bundle-add qt-basic-dev devpkg-SDL2 deprecated-python2
Clone yuzu
cd ~/Downloads
git clone --recursive https://github.com/yuzu-emu/yuzu-mainline
cd yuzu-mainline && mkdir build && cd build
Fix things to make it compiling (replacing boost 1.71 in requirements with 1.73)
Finally make
cmake .. -GNinja
ninja
strip bin/*
This is the yuzu master repo you are building not the mainline.thanks anyways
Mainline compilation working as well .
- Added strip command =)
Yes it is.thank you .
whats a strip command?
http://reverse.lostrealm.com/protect/strip.html
tldr: reduce compiled file size by removing debug information from the file
Gives me File format error behen I run btw
