Anybody got a clue of what to do next?
I have had the same problem. The iso release 43630 work on qemu/kvm, but using in a real boot don’t work and freeze on this step.
Note: for working on qemu/kvm I needed access the virtual machine by ssh and reinstall bundles Xorg and some related. After this, I could use this release.
The developers highly recommend using the IMG image to burn the flash drive.
Read here: Unable to run Clear Linux installer (43490)
That’s rubbish. ISO format is the standard, and even if wasn’t, the .img is 15GiB, or 16.1GB, requiring a 32GB USB drive, which I don’t have, and it’s sort of a ludicrous requirement regardless.
Try rufus with dd copy method. For the recent clrlinux iso releases it works well.
The initial error lies in the boot process which looks for a partition named: CLR_ISO
An easy test for it: if you have ever changed the partition label of the clrlinux USB live to anything rather than CLR_ISO, it won’t boot.
