Metric connection change
Good day from Sweden, :grinning_face_with_smiling_eyes: :grinning_face_with_smiling_eyes:I just managed to install Clear Linux, it is a huge change from Xubuntu on my Legion.
Now, Iโ€™d wish to use my 5G data connection for automatic updates et al, but I just cannot figure how to make it happen.
Thanks a million for helping out
Erika
et alii can only be used on men or group of men and women.
you should use et cetera here to refer to inanimate objects.
Whatโ€™s blocking you?
hiya thanks, I solved the issue, the hint was to go to network settings or the like, now, this one was instead thru the updates option.
have a good day
Erika
