Missing Botan 2, CMAKE
Hi guys.
I’m trying to manually install a program called CoreCntrl as per the manual install process here
git clone https://gitlab.com/corectrl/corectrl.git
cd corectrl
mkdir build
cd build
cmake -DCMAKE_INSTALL_PREFIX=/usr -DCMAKE_BUILD_TYPE=Release -DBUILD_TESTING=OFF …
make
BUT, i get the error " – Checking for module ‘botan-2’
– No package ‘botan-2’ found"
I’ve installed what i thought would be the relevant bundles.
Can someone help me install Botan 2 so i can install Corecntrl.
Thank you :slight_smile:
I’ve added config to make a devpkg-botan-2. If you want to manually install the Botan-dev rpm (and possibly lib) to work around this, it is also an option.
Hello thank you for getting back to me so quickly !
Do you mean you’ve added a devpkg-botan-2 to the software section ?
May i ask, how would i manually install the Botan-dev rpm and lib ?
I’m sorry , still learning :slight_smile: I’ve been spoon fed too much via Ubuntu lol.
Kind regards,
Sean
Hi William.
Just following up on this. How would I add the rpm manually ? Also, will botan become part of one of the dev packages available in the software depository?
I’m fairly new to Linux and just need a little guidance to overcome this hiccup and I’ll be raring to go !
Thank you,
Sean
