It showed two warnings and after my terminal was blank, I tapped Ctr+Alt+F3, it opened a new window and i typed ârebootâ, after I saw same terminal without graphic interface again, so I finished typing:
âlsmod | grep ^nvidiaâ than
âsudo swupd repair --quick --bundles=lib-openglâ and
âln -sv /opt/nvidia/share/applications/nvidia-settings.desktop $HOME/.local/shareâ
than ârebootâ and I got my desktop :3 But I canât find or run nvidia-setting or any nvidia command. Someone know why ? It should be in my quick access apps i guess. Hmmm.
Oh no. I power off my PC and when I wanted to turn it on, every time I get non graphic terminal , and âNvidiafb: cannot requests PCI regionsâ notification. I tried to smash âeâ button to modify the boot parameters and add black list with nouveau as recommended on other threads, I did it, but no effect. Please help me.
The nvidia utilities should be under /opt/nvidia/bin after installation.
If youâre stuck in a state where you canât access an interface or alternate terminal, boot with the kernel parameter systemd.unit=multi-user.target. That will not launch and graphical parts so you can investigate.
Now I can access my desktop with graphical parts, I reinstalled nvidia drivers, and this time after installation it changed to graphical interface automatically, nice. Itâs funny now, that when I power on my PC I got same âNvidiafb: cannot requests PCI regionsâ, but after a while it is working and going forward.
But still missing nvidia utilities. Well -> /opt/nvidia/bin I got that, there are scripts in this folder, but none of them is working.
I have no idea how should they work, but when I want to run ânvidia-settingsâ by clicking on it, nothing happens. Also there is no such a command like ânvidia-settingâ and generally there is no app in the launcher for easy access as I understand this command âln -sv /opt/nvidia/share/applications/nvidia-settings.desktop $HOME/.local/shareâ should do.
ERROR: libnvidia-gtk3.so.440.44: cannot open shared object file: No such file
or directory
libnvidia-gtk3.so: cannot open shared object file: No such file or
directory
libnvidia-gtk2.so.440.44: cannot open shared object file: No such file
or directory
libnvidia-gtk2.so: cannot open shared object file: No such file or
directory
ERROR: A problem occured when loading the GUI library. Please check your
installation and library path. You may need to specify this library when
calling nvidia-settings. Please run /opt/nvidia/bin/nvidia-settings --help for usage information."
As I suggested, you need to add /opt/nvidia/bin to your PATH.
For the problem with the library, did you configured /etc/ld.so.conf and like in the tutorial?
Well. I did uninstall, cleaning, pre_install, install and post_install and got the same situatin, no changes.
Same two warnings until installation:
WARNING: Unable to determine the default library path. The path /opt/nvidia/lib will be used, but this path was not detected in the ldconfig(8) cache, and no directory exists at this path, so it is likely that libraries installed there will not be found by the loader.
WARNING: Unable to determine the default X library path. The path /opt/nvidia/lib will be used, but this path was not detected in the ldconfig(8) cache, and no directory exists at this path, so it is likely that libraries installed there will not be found by the loader.
I took it from install log.
So still same situation, no nvidia utilities and shortcuts.
