Needing to migrate from a postgresql v9.6 installation to postgresql v12.x on a CL server. (Version 31700)
Since Postgresql mainline is three major versions ahead, it’s unlikely that data files from v9.6 will be binary compatible with v12.x. Hence nervous to try upgrade in place, as have little confidence it will work.
Current plan is hoping to do a dump and restore on the same server between versions. i.e.
pg_dump postgres > postgres_db.bak
then psql empty_database < backup_file
on pgsql v12
Open to other ideas too
