Dear All,
I’m experiencing quite a lot of instabilities on Clear Linux nowadays.
I just experienced the following crash today:
<27>Nov 26 20:45:40 smbd[1197]: INTERNAL ERROR: Signal 11: Segmentation fault in pid 1197 (4.13.2)
With the following message a bit later: If you are running a recent Samba version, and if you think this problem is not yet fixed in the latest versions, please consider reporting this bug, see https://wiki.samba.org/index.php/Bug_Reporting
Am I the only one in this situation?
I’m just wondering if I must stay with this distribution or change to another one.
Wouldn’t recommend CL for samba. Something a little more mainstream and handsy with the wins community would be better. Or something truly multipurpose, like debian. Or an appliance. Unless your running it with distributed CEPH on top of k8s or something – this model works fine on CL btw.
For a simple home server I would recommend debian or ubuntu depending on your experience level. Or if you are looking to set and forget go with centos8.
Thanks for the advice. The thing is that these OpenMediaVault, FreeNAS, Ubuntu, Debian, are quite bloated with plenty of things you can’t really remove.
I’ve tested them all, but was not satisfied.
I want to start with something quite clean and lean. Therefore I still think Clear Linux is a good candidate.
For sure I could got with OpenWrt, but they are a bit behind regarding the kernel version.
Anyway, I still need to test some other configurations.
Thanks again for taking your time to reply.
