Jun 25 18:26:20 clr pavucontrol[5133]: gdkwindow-x11.c:5611 drawable is not a native X11 window
Jun 25 18:26:20 clr kernel: show_signal_msg: 190 callbacks suppressed
Jun 25 18:26:20 clr kernel: pavucontrol[5133]: segfault at 0 ip 0000000000000000 sp 00007ffcb3bec268 error 14 in pavucontrol[55ff4f910000+27000]
Jun 25 18:26:20 clr kernel: Code: Bad RIP value.
Jun 25 18:26:20 clr systemd[1]: Started Process Core Dump (PID 5142/UID 0).
Jun 25 18:26:20 clr systemd[1]: Started Telemetrics Daemon.
Jun 25 18:26:20 clr systemd[1]: Started Telemetrics Post Daemon.
Jun 25 18:26:30 clr systemd-coredump[5145]: Failed to compress (unnamed temporary file): Protocol not supported
Jun 25 18:26:31 clr systemd[1]: Started Clear Linux debuginfo daemon.
Jun 25 18:26:31 clr systemd-coredump[5145]: Process 5133 (pavucontrol) of user 1000 dumped core.
Does this mean you get all data about segfault? Or do you need explicit bug reports? I have opted-in to telemetry.
Jun 25 18:32:31 clr systemd[1]: telemprobd.service: Succeeded.
Jun 25 18:32:31 clr telempostd[5149]: Record deliver failed after 8 attempts
Jun 25 18:32:31 clr systemd[1]: telempostd.service: Succeeded.
What does this mean? Failed or succeeded? Did you get segfault record
org.clearlinux/crash/error Tue 2019-06-25 18:26:30 CEST b0536ca427d78a6cafa5a0185ad0d485 ac29489205dd44335ec0dba6862ef679 260c0d55-9013-46aa-abba-6f068358d89e
If it’s necessary to report manually do you have a pastebin service (similar to fpaste.org from Fedora) where to paste kernel dumps?
Please clarify.
