Hello Guys,
it has been a while since I have written something in this forum, but recently I tried to install jenkins on my computer. When I wanted to follow the process of
So the process of me was the following:
sudo wget -O /etc/yum.repos.d/jenkins.repo \ https://pkg.jenkins.io/redhat-stable/jenkins.repo sudo rpm --import https://pkg.jenkins.io/redhat-stable/jenkins.io.key sudo dnf check-update sudo dnf download jenkins sudo rpm -U --nodeps ./jenkins*.rpm //this throws the error
After pressing enter at the last command it rains error messages of jenkins not finding some binaries. This made me curious and so I searched the binaries by myself and found them. The error message is like this:
Fehler:
Problem: conflicting requests
- nothing provides /bin/sh needed by jenkins-2.263.1-1.1.noarch
- nothing provides /usr/sbin/groupadd needed by jenkins-2.263.1-1.1.noarch
- nothing provides /usr/sbin/useradd needed by jenkins-2.263.1-1.1.noarch
- nothing provides procps needed by jenkins-2.263.1-1.1.noarch
(try to add ‘–skip-broken’ to skip uninstallable packages)
I do not know what I am doing wrong, but I really hope that someone of you is able to help me with my problem.
