Trouble installing Clear Linux OS.
During the installation process, a message appears: SGX disabled by BIOS. Further installation does not go. At the same time, in the BIOS, the SGX option is in the [Software Controlled] position. Motherboard
Asus PRIME Z490-P, intel 10700 processor.
Make sure your CPU and BIOS combination support it.
Thanks a lot for your answer! But what should I do in the end to install Clear Linux OS?
Or is it not possible?
As far as I understand, there is support for the SGX.
Since your CPU supports it, see if the BIOS selection for SGX can be changed to “hardware” instead of software. If hardware isnt a choice, see if there is an “auto” setting.
Briefly, the problem is that it is not possible to install Clear Linux OS if the SGX setting in your BIOS is set to Software Controlled.
