Unable to Include clr-installer in Custom Clear Linux ISO via Mixer
Hi team,
We’re building a custom Clear Linux ISO using mixer. We followed the standard procedure:
Summary:
  1. Initialized mixer with a known version:
    sudo mixer init --clear-version 43070 --mix-version 1
  2. Added clr-installer to mixer.bundles along with other required bundles.
  3. Ran mixer build all and mixer build image successfully.
  4. Verified release.iso is generated.
Problem:
Even though clr-installer is added to mixer.bundles, it does not show up in mixbundles and is not available in the booted live system. Trying to install it via swupd fails due to lack of network access and missing MoM metadata (<URL where the content will be hosted>/1/Manifest.MoM.tar).
We tried:
  • Rebuilding from scratch with different Clear Linux versions (43460, 43290, etc.).
  • Adding both clr-installer and clr-installer-iso-init explicitly.
  • Cleaning upstream-bundles/ before reinitializing.
  • Verified swupd search clr-installer on host system shows it’s available.
  • Adding extra bundles assuming clr-installer is dependent on them:
storage-utils
openssh-server
wpa_supplicant
iwd
NetworkManager
Steps I followed:
  1. sudo mixer init --clear-version 43070 --mix-version 1
  2. vi mixer.bundles
os-core
kernel-native
bootloader
network-basic
python3-basic
python3-pip
desktop-autostart
x11-server
opencl
gstreamer
containers-basic
containers-utils
usbutils
c-basic
dev-utils
java-basic
gstreamer-dev
clr-installer
  1. sudo mixer build bundles
  2. sudo mixer build update
  3. sudo mixer build image
  4. release.iso is generated
Now, i try to run it in qemu:
7. mkdir -p vm && cd vm
8. qemu-img create -f qcow2 clearlinux-test.img 20G
9. sudo qemu-system-x86_64 -enable-kvm -cpu host -m 4096 -smp 4 -cdrom ../release.iso -boot d -hda clearlinux-test.img -net nic -net user -vga virtio -serial mon:stdio
then this happens when the image is boot:
root@clr-944e6ec88a434e12a9a6753b7ff0242c ~ # clr-installer
clr-installer: command not found
To install clr-installer use: swupd bundle-add clr-installer
root@clr-944e6ec88a434e12a9a6753b7ff0242c ~ # swupd bundle-add clr-installer
Error: Failed to connect to update server: /1/Manifest.MoM.tar
Detailed qemu logs:
sr@clr-35cef7c8491b4989a6e807579c737c7c:~/Downloads/edge-installation-scripts/clear_linux_iso/vm (master)$ sudo qemu-system-x86_64   -enable-kvm   -cpu host   -m 4096   -smp 4   -cdrom ../release.iso   -boot d   -hda clearlinux-test.img   -net nic -net user   -vga virtio   -serial mon:stdio
[    0.112437] sched_ext: Failed to register kfunc sets (-22)
Using /dev/console for output
Checking if system is capable of running Clear Linux*...
egrep: warning: egrep is obsolescent; using grep -E
[  OK  ] 64-bit CPU (lm)
[  OK  ] Supplemental Streaming SIMD Extensions 3 (ssse3)
[  OK  ] Streaming SIMD Extensions v4.1 (sse4_1)
[  OK  ] Streaming SIMD Extensions v4.2 (sse4_2)
[  OK  ] Carry-less Multiplication extensions (pclmulqdq)
[  OK  ] All checks passed.
[  OK  ] Found installer media, continuing boot...
clr-944e6ec88a434e12a9a6753b7ff0242c login: root
You are required to change your password immediately (administrator enforced).
New password:
Retype new password:
root@clr-944e6ec88a434e12a9a6753b7ff0242c ~ # ls
clr-installer.log  clr-installer.yaml
**Error: Failed to connect to update server: <URL where the content will be hosted>/1/**Manifest.MoM.tar
Possible solutions for this problem are:
	Check if your network connection is working
	Fix the system clock
	Run 'swupd info' to check if the urls are correct
	Check if the server SSL certificate is trusted by your system ('clrtrust generate' may help)
Error: Failed to retrieve 1 MoM manifest
Error: Cannot load official manifest MoM for version 1
Failed to install 1 of 1 bundles
root@clr-944e6ec88a434e12a9a6753b7ff0242c ~ # clrtrust generate
Trust store generated at /var/cache/ca-certs
Error: Failed to connect to update server: <URL where the content will be hosted>/1/Manifest.MoM.tar
Despite all this, clr-installer never makes it into the ISO.
Any guidance on how to correctly bundle clr-installer into a custom ISO would be appreciated.
Thanks!
Rikin
