I noticed when running ‘systemctl status’ that the system state was ‘degraded’.
It turns out the service ‘systemd-boot-system-token.service’ had failed.
The error is reported as follows:
● systemd-boot-system-token.service - Store a System Token in an EFI Variable
Loaded: loaded (/usr/lib/systemd/system/systemd-boot-system-token.service; static; vendor preset: disabled)
Active: failed (Result: exit-code) since Mon 2019-10-28 14:17:43 GMT; 2min 49s ago
Docs: man:systemd-boot-system-token.service(8)
Process: 348 ExecStart=/usr/bin/bootctl random-seed (code=exited, status=1/FAILURE)
Main PID: 348 (code=exited, status=1/FAILURE)
Oct 28 14:17:43 pythagoras systemd[1]: Starting Store a System Token in an EFI Variable...
Oct 28 14:17:43 pythagoras bootctl[348]: Couldn't find EFI system partition. It is recommended to mount it to /boot or /efi.
Oct 28 14:17:43 pythagoras bootctl[348]: Alternatively, use --esp-path= to specify path to mount point.
Oct 28 14:17:43 pythagoras systemd[1]: systemd-boot-system-token.service: Main process exited, code=exited, status=1/FAILURE
Oct 28 14:17:43 pythagoras systemd[1]: systemd-boot-system-token.service: Failed with result 'exit-code'.
Oct 28 14:17:43 pythagoras systemd[1]: Failed to start Store a System Token in an EFI Variable.
Sure enough, /boot is not mounted on my system. I’m not sure if this is intended to be auto-mounted in Clear Linux. I don’t have an /etc/fstab, so the partitions mounted are whatever was configured by default by the installer. I have not changed any configuration related to partitions.
