if fish is the users shell and /usr/share/defaults/etc/profile is not sourced.
# /etc/fish/config.fish: system-wide .profile for the fish shell (fish(1))
# Add /usr/bin, the avx2/avx512 bin paths to PATH as needed
# Then cleanup symlink paths
set -l paths /usr/bin
if grep -q "flags.*:.* avx512bw" /proc/cpuinfo
set -a paths /usr/bin/haswell/avx512_1
else if grep -q "flags.*:.* fma .* avx2" /proc/cpuinfo
end
set -a paths /usr/local/bin ~/.local/bin
for path in $paths
if not contains $path $PATH
set -p --path PATH $path
end
end
# Remove from beginning/end/middle of PATH
set -l num 0
set -l bad_indexes
set -l bad_paths /bin /sbin /usr/sbin
for path in $PATH
set -l num $(math 1+$num)
if contains $PATH[$num] $bad_paths
set -a bad_indexes $num
end
end
if test -n $bad_indexes
set -e PATH[$bad_indexes]
end
if test -x /bin/vi
set -x EDITOR /usr/bin/vi #needed for packages like cron
else
set -x EDITOR /usr/bin/nano #needed for packages like cron
end
if not test -e /etc/localtime
set -x TZ UTC
end
set -x CFLAGS -g -O3 -feliminate-unused-debug-types -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -Wformat -Wformat-security -m64 -fasynchronous-unwind-tables -Wp,-D_REENTRANT -ftree-loop-distribute-patterns -Wl,-z -Wl,now -Wl,-z -Wl,relro -fno-semantic-interposition -ffat-lto-objects -fno-trapping-math -Wl,-sort-common -Wl,--enable-new-dtags -mtune=skylake -mrelax-cmpxchg-loop
set -x FFLAGS -g -O3 -feliminate-unused-debug-types -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -m64 -fasynchronous-unwind-tables -Wp,-D_REENTRANT -ftree-loop-distribute-patterns -Wl,-z -Wl,now -Wl,-z -Wl,relro -malign-data=abi -fno-semantic-interposition -ftree-vectorize -ftree-loop-vectorize -Wl,--enable-new-dtags
set -x FCFLAGS -g -O3 -feliminate-unused-debug-types -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -m64 -fasynchronous-unwind-tables -Wp,-D_REENTRANT -ftree-loop-distribute-patterns -Wl,-z -Wl,now -Wl,-z -Wl,relro -malign-data=abi -fno-semantic-interposition -ftree-vectorize -ftree-loop-vectorize -Wl,-sort-common -Wl,--enable-new-dtags
set -x CXXFLAGS $CFLAGS -fvisibility-inlines-hidden -Wl,--enable-new-dtags
set -x AR gcc-ar
set -x RANLIB gcc-ranlib
set -x NM gcc-nm
set -x LA_VERSION "OpenBLAS"
set -x LA_LIBS /usr/lib64/libopenblas.so.0
set -x LA_INCLUDE /usr/include
set -x LA_PATH /usr/lib64/
set -x MPI_CC /usr/bin/mpicc
set -x MPI_LIBS /usr/lib64/libmpi.so
set -x MPI_INCLUDE /usr/include/
set -x MPI_PATH /usr/lib64/
set -x MPI_VERSION 3.2
set -x THEANO_FLAGS 'floatX float32,openmp true,gcc.cxxflags "-ftree-vectorize -mavx"'
set -x CC gcc
set -x CXX g++
set -x PYTHONIOENCODING utf-8:surrogateescape
set -x MESA_GLSL_CACHE_DISABLE 0
set -x GTK_IM_MODULE "ibus"
set -x JAVA_INCLUDE_PATH /usr/lib/jvm/java-1.18.0/include
set -x RUSTFLAGS '-C target-cpu=native'
set -l vars /usr/local/lib{,64}/pkgconfig/ /usr/local/share/pkgconfig
for var in $vars
if not contains $var $PKG_CONFIG_PATH
set -ax PKG_CONFIG_PATH $var
end
end
for langfile in /usr/share/defaults/etc/locale.conf /etc/locale.conf "$HOME/.i18n"
if test -f $langfile
for var in $(cat $langfile)
set -x $(string split ' ' $(string replace = ' ' $var))
end
end
end
set -x --path XDG_CONFIG_DIRS /usr/share/xdg /etc/xdg
umask 022
