n the installer, in the advanced settings, there is a choice: whether to install GIMP and by default the tick is unchecked, but after installing GIMP there is a system, why?
It was only 5 minutes that I started to learn Clear OS, is it worth continuing if there are already errors?
This is likely installed by other bundles, like desktop.
❯ sudo swupd search gimp -a
Component gimp has version 2.10.18
Bundle with the best search result:
gimp - GNU Image Manipulation Program. (225MB) (installed)
This bundle can be installed with:
swupd bundle-add gimp
Alternative bundle options are
devpkg-gimp - All content for pkgconfig file gimp.pc. (157MB) (installed)
education - Educational applications. (2MB)
desktop-apps-extras - Larger set of applications for the desktop. (433MB)
os-testsuite-phoronix - Run the Phoronix test suite. (1MB)
os-testsuite-phoronix-desktop - Run the Phoronix test suite (desktop version). (215MB)
desktop - Run the GNOME GUI desktop environment. (357MB) (installed)
desktop-dev - All packages required to build the desktop bundle. (2956MB) (installed)
