I’ve used Intel Advisor (and played a bit with VTune) on Clear Linux, as part of their DPC++ suite. Especially in older versions, you might have some missing driver/libraries warnings, but everything works just fine with no visible issue as far as I can tell.
Quite useful, especially when combined with Nsight to profile GPU computing.
I do. I am a Intel OneApi fanboy and i use all of Intels analyze tools, Vtune, Advisor, Intel GDB and Intel ITT/JIT profiling API. Also finding it hard to not use OneApi DPL with its nice higher level sycl interfaces in any code i write now.
I can honestly say ClearLinux is the worst developer platform for OneApi, Use Fedora or Ubuntu instead if you want to do/use any OneAPi tools in your development, i tried having ClearLinux as a daily OS for OneAPi but its messy.
You would think Intel ClearLinux and Intel OneAPi would make the perfect developer desktop workstation setup, Intel OneApi being a first class citizen on Intel ClearLinux desktop. But sadly its not.
