Yeah, I was going to suggest this next - run everything as root (services, etc) and then add yourself to the right groups for actually managing VMs
What issues are you having with Open vSwitch? In my experience, it’s pretty much the same across all distributions. Start the service, then use ovs-vsctl
to configure the network. On my Clear Linux hosts, I’m using Open vSwitch to manage the interface configurations - bonds, vlans, bridges, etc. - and then systemd to actually assign the IPs to the resulting virtual interfaces, and it seems to be working fine. (this is how other solutions like proxmox use it, iirc)
Hi Marioroy,
KVM works fine for me. I too have my USER added to the following groups
$ groups
wheel qemu kvm libvirt kvmadm
Is there a group for access to openvswitch through KVM.
Regards
Gorian,
I think I may have worded the question incorrectly, and may have been misinterpreted. Openvswitch works just fine, as root, as it does in other distributions. I can create bridges, VLAN etc. What I can’t find is how I can give a user rights to doing the configurations. Is there a specific group I can add the user too. Or chmod a directory/file?
Kind Regards
Alright so I configured kvm using root.
$ sudo virsh net-list
Name State Autostart Persistent
ovs-network active yes yes
$ sudo virsh pool-list
iso active yes
vms active yes
# Also installed the VM using root which works fine.
$ sudo virt-install --name toad --memory 4096 --disk toad.qcow2,pool=vms,bus=virtio,size=10 --vcpus 2 --os-variant debian11 --network network=ovs-network,model=virtio --graphic spice,listen='0.0.0.0' --boot hd --noautoconsole --features kvm_hidden=on --autostart --cdrom /opt/kvm/iso/debian-11.7.0-amd64-netinst.iso
Starting install...
Allocating 'toad.qcow2' | 0 B 00:00:00 ...
Creating domain... | 0 B 00:00:00
Domain is still running. Installation may be in progress.
You can reconnect to the console to complete the installation process.
# And I can see VM running
$ sudo virsh list
Id Name State
2 toad running
If I try seeing/managing this as the user - they see nothing.
$ virsh list --all
Id Name State
$ virsh net-list --all
$ virsh pool-list --all
How do I give USER access to the VMs created under root account?
Yay! I have resolved the issue - such a simple and stupid mistake!
I forgot to create ~/.config/libvirt/libvirt.conf
with the following line:
uri_default = "qemu:///system"
I missed it in my notes! Aaaghhh!!
Really appreciate your help.
Happy to post the full deployment here for anyone else
Hi All,
Here is my working solution.
After Initial installation of Clear Linux.
- add user kadmin
Change the hostname
sudo hostnamectl hostname kvm01
Add Required Bundles
Install the KVM bundles
sudo swupd bundle-add kvm-host
Install the tools for creating virtual machines
sudo swupd bundle-add virt-manager
Install Openvswitch bundle.
sudo swupd bundle-add openvswitch
Install vim for modifying files.
##### Optional Bundles
sudo swupd bundle-add vim
Add wget for pulling down ISO images
sudo swupd bundle-add wget
Install Network Basics which will give you ping command
sudo swupd bundle-add network-basic
Add user to groups
Set permissions for user
sudo usermod -G kvm -a kadmin
# Add access to virsh commands
sudo usermod -G libvirt -a kadmin
# refresh the group.
exec newgrp kvm
exec newgrp libvirt
exec newgrp kvmadm
Enable and start required services
sudo systemctl enable libvirtd
sudo systemctl start libvirtd
Disable network manager
sudo systemctl status NetworkManager
sudo systemctl stop NetworkManager
sudo systemctl disable NetworkManager
sudo systemctl mask NetworkManager
Enable systemd-networkd.
sudo systemctl status systemd-networkd
sudo systemctl enable systemd-networkd
sudo systemctl start systemd-networkd
sudo systemctl enable systemd-resolved
Enable openvswitch services
sudo systemctl enable openvswitch
sudo systemctl start openvswitch
System Configurations
(Optional) Before starting configure default vim file.
touch ~/.vimrc
mkdir -p ~/.config/libvirt
vim ~/.config/libvirt/libvirt.conf
# Add line to file
Create network configuration files.
sudo mkdir -p /etc/systemd/network/
Create a bridge network file sudo vim /etc/systemd/network/70-ovs-br0.network
[Match]
Name=ovs-br0
[Network]
DHCP=yes
Copy the default sudo vim /etc/systemd/network/71-ovs-br0-eno1.network file for the ethernet adapter…
[Match]
Name=eno1
[Network]
Bridge=ovs-br0
IPForward=ipv4
OpenvSwitch configuration - Run direct terminal - will lose network connectivity.
Show the openvswitch configuration
sudo ovs-vsctl show
6aa580b5-5f3a-4dfe-9d0c-ad8addd0078a
ovs_version: "3.1.0"
Create network bridge in ovs before resetting systemd-network
sudo ovs-vsctl add-br ovs-br0
sudo ovs-vsctl add-port ovs-br0 eno1
sudo ip link set ovs-br0 up
sudo systemctl restart systemd-networkd
Create KVM folders - still working out permissions
sudo mkdir -p /opt/kvm/vms
sudo mkdir -p /opt/kvm/iso
sudo chmod -R 775 /opt/kvm/
sudo chown -R root:kvm /opt/kvm
sudo chmod -R g+s kvm/
Define Networks
In home directory create network.xml
<network>
<name>ovs-network</name>
<forward mode='bridge' />
<bridge name='ovs-br0' />
<model type='virtio'/>
<virtualport type='openvswitch' />
<portgroup name='native' default='yes' />
<portgroup name='vlan60'>
<vlan>
<tag id='60' />
</vlan>
</portgroup>
<portgroup name='vlan80'>
<vlan>
<tag id='80' />
</vlan>
</portgroup>
</network>
Define network in kvm
virsh net-define network.xml
virsh net-start ovs-network
virah net-autostart ovs-network
Define Storage
In home directory create store.xml
<pool type="dir">
<name>vms</name>
<target>
<path>/opt/kvm/vms</path>
</target>
</pool>
Define storage in kvm
virsh pool-define store.xml
virsh pool-start vms
virah pool-autostart vms
Create a VM on native VLAN
virt-install --name cl01 --memory 2048 --disk cl01.qcow2,pool=vms,bus=sata,size=15 --vcpus 2 --os-variant clearlinux --network network=ovs-network,model=virtio --graphic spice,listen='0.0.0.0' --boot hd --noautoconsole --features kvm_hidden=on --autostart --cdrom /opt/kvm/iso/clear-39030-live-server.iso
Create a VM on VLAN 60
virt-install --name cl02 --memory 2048 --disk cl02.qcow2,pool=vms,bus=sata,size=15 --vcpus 2 --os-variant clearlinux --network network=ovs-network,portgroup='vlan60',model=virtio --graphic spice,listen='0.0.0.0' --boot hd --noautoconsole --features kvm_hidden=on --autostart --cdrom /opt/kvm/iso/clear-39030-live-server.iso
Regards
Hi All,
Going to add to the install above, as I was missing a few bits, which may help others looking to run KVM under ClearLinux.
Run virt-host-validate. In my case I had a few outstanding FAILs.
Doing a quick search I found I had to add a couple lines into boot loader.
sudo vim /etc/kernel/cmdline.d/iommu.conf
intel_iommu=on
systemd.unified_cgroup_hierarchy=0
sudo clr-boot-manager update
Enable auto starting VMs after a reboot.
sudo systemctl enable libvirt-guests
sudo systemctl start libvirt-guests
sudo systemctl status libvirt-guests
Create the libvirt-guest files.
sudo mkdir -p /etc/sysconfig
sudo vim /etc/sysconfig/libvirt-guests
Add the following. I found if you don’t have a start delay you get errors with OVS mtu and corrupt managed state save files.
START_DELAY=20
ON_SHUTDOWN=shutdown
Cheers.
