Documentation:
Burn the image onto the USB drive. The example below burns an uncompressed image onto :
dd if=./clear-[version number]-[image type] of= oflag=sync bs=4M status=progress
Documentation:
Hey, welcome!
I agree, the documentation is too indirect about doing the decompression. I noticed this last week and registered this issue to have it updated:
Feel free to add any more suggestions to the issue. There is also a linked discussion on whether the ISO file should be compressed going forward.
This threw me for a loop a bit; I believe the devs found and used Rufus for Windows, which is really simple solution. Yes, I agree, isn’t exactly easy for people coming from linux…
