I have installed xrdp bundle and then created the cert/pem required by xrdp. This allows me to connect to the RDP session but when trying to login, i get “Login failed for display 0”. Any workaround and is this a known issue? This is using Xorg method not VNC.
This is the closet issue i could find on the matter but it is closed. Maybe the issue has resurfaced?
I’ve wasted the whole afternoon trying to get something done. xrdp fails to pass credentials to PAM like in your case, and VNC viewer shows “Oh no! Something went wrong” error with the only choice to log out.
