Hello ,
the automatic mount by fstab, does not work for network units.
After full boot, ‘sudo mount -a’ works normally.
My network drives require a login/password that is in /root/.credentials
Is a mistake on my part?
Is there a way to set a delay before mounting the network units?
@clr-jpb~ sudo systemctl list-units --all *.mount
Mot de passe :
UNIT LOAD ACTIVE SUB DESCRIPTION
-.mount loaded active mounted /
● **home-JeanPhilippe-svg.mount** loaded **failed** **failed** /home/JeanPhilippe/svg
● **home-JeanPhilippe-synodev.mount** loaded **failed** **failed** /home/JeanPhilippe/synodev
proc-sys-fs-binfmt_misc.mount loaded inactive dead Arbitrary Executable File Formats File System
run-user-1000-doc.mount loaded active mounted /run/user/1000/doc
run-user-1000-gvfs.mount loaded active mounted /run/user/1000/gvfs
run-user-1000.mount loaded active mounted /run/user/1000
● sys-fs-fuse-connections.mount not-found inactive dead sys-fs-fuse-connections.mount
● sys-kernel-config.mount not-found inactive dead sys-kernel-config.mount
tmp.mount loaded active mounted Temporary Directory (/tmp)
usr-lib-debug.mount loaded active mounted /usr/lib/debug
usr-src-debug.mount loaded active mounted /usr/src/debug
var-lib-machines.mount loaded inactive dead Virtual Machine and Container Storage (Compatibility)
@clr-jpb~ sudo mount -a
@clr-jpb~ $ sudo systemctl list-units --all *.mount
home-JeanPhilippe-svg.mount loaded active mounted /home/JeanPhilippe/svg
home-JeanPhilippe-synodev.mount loaded active mounted /home/JeanPhilippe/synodev
