I can’t find any mention of firewall configuration in the documentation.
I can’t find any packages apart from iptables
For example it would me handy to have ufw, since iptables is very obtuse to configure.
Clear Linux has no firewall when you install it. By default, all ports are open. By default, only SSH is listening.
What is your firewall use case?
Running a server, I just wanted to block all incoming + outgoing connections on all ports except the services I’m running. I’m reading up on iptables at the moment anyway, but one complication is Docker creates a bunch of iptables rules so I’ll have to boot up with Docker disabled, create and save the rules, and enable it again.
I wasn’t sure where to save the rules file, but I found /usr/lib/systemd/system/iptables-restore.service which loads from /etc/iptables.rules. I guess this should be documented somewhere eventually
@ljmccarthy fair enough. Those locations/commands are part of iptables and not too unique to CL, so documentation for it hasn’t been a high priority for it so far. I added a request to get it documented though: Document iptables firewall and default rulesets · Issue #541 · clearlinux/clear-linux-documentation · GitHub
These are standard and come from upstream. man iptables-save
to start. Follow the SEE ALSO
references therein to related documents.
Pls, how to install any firewall gui?
debian, ubuntu, fedora, suse …
this is not a problem!
gufw
is a frontend to ufw
which I’ve decided NOT to include. ufw
is too debian/ubuntu centric to integrate nicely and would likely be too much work to include.
Instead, we will have firewalld
available within a few days. This still likely needs to be polished up a bit so please help by test and give feedback on the firewalld
bundle once it becomes available. We will look into adding firewall-config
at a later point in time when it all works OK.
I will try it out when it lands. Cheers
Hi,i tried firewalld ,enabled the daemon and is running but have failure whenI check the status:
sudo firewall-cmd --state
because not find //etc/firewalld/firewalld.conf.
Now im back to iptables but I will to try firewalld.is here something to copy to /etc… or to create this config file manual?
The missing /etc
file message is more dramatic than it seems and doesn’t directly cause the failed firewalld state. The fix is merged upstream and pending a new release, more details here: firewalld does not work with the default nftables backend · Issue #1123 · clearlinux/distribution · GitHub
4 posts were split to a new topic: Firewalld missing nft errors
