Upgraded from 36420 to latest and Firewalld stopped working. Replicated the issue on second server.
Unfortunately not too much useful information in the logs:
systemctl status firewalld
× firewalld.service - firewalld - dynamic firewall daemon
Loaded: loaded (/usr/lib/systemd/system/firewalld.service; disabled; vendor preset: disabled)
Active: failed (Result: exit-code) since Sun 2022-06-19 08:41:35 PDT; 4min 57s ago
Docs: man:firewalld(1)
Process: 7578 ExecStart=/usr/bin/firewalld --nofork --nopid $FIREWALLD_ARGS (code=exited, status=1/FAILURE)
Main PID: 7578 (code=exited, status=1/FAILURE)
Jun 19 08:41:35 ****** systemd[1]: Starting firewalld - dynamic firewall daemon...
Jun 19 08:41:35 ****** systemd[1]: firewalld.service: Main process exited, code=exited, status=1/FAILURE
Jun 19 08:41:35 ****** systemd[1]: firewalld.service: Failed with result 'exit-code'.
Jun 19 08:41:35 ****** systemd[1]: Failed to start firewalld - dynamic firewall daemon.
journalctl -xeu firewalld.service
Jun 19 08:41:35 ******* systemd[1]: Starting firewalld - dynamic firewall daemon...
░░ Subject: A start job for unit firewalld.service has begun execution
░░ Defined-By: systemd
░░ Support: https://lists.freedesktop.org/mailman/listinfo/systemd-devel
░░ A start job for unit firewalld.service has begun execution.
░░ The job identifier is 684.
░░ Subject: Unit process exited
░░ An ExecStart= process belonging to unit firewalld.service has exited.
░░ The process' exit code is 'exited' and its exit status is 1.
Jun 19 08:41:35 ******* systemd[1]: firewalld.service: Failed with result 'exit-code'.
░░ Subject: Unit failed
░░ The unit firewalld.service has entered the 'failed' state with result 'exit-code'.
Jun 19 08:41:35 ******* systemd[1]: Failed to start firewalld - dynamic firewall daemon.
░░ Subject: A start job for unit firewalld.service has failed
░░ A start job for unit firewalld.service has finished with a failure.
░░ The job identifier is 684 and the job result is failed.
I’m guessing could be related to the python3 version. Do not think Firewalld was updated between latest versions some dependency has changed.
