Dear Clear Linux community
Problem
Every now and then the hardware keyboard fails. If I start the console, it does not work. If I start a new window in the console, it can work again. The same with the browser Brave or with the software LibreOffice Writer. In the latter case, Writer is started, keyboard does not work, if you leave it open, it can work again on its own after a while. I usually restart Writer again and again until it works. But then it often happens that you cannot write in the font or search field, but you can in the general text field for editing the document.
These are just examples to illustrate the problem.
Info
Everything worked in Windows.
Another distribution of Linux also worked.
System & diagnosis
Champion@clr-a454e39f8f34433ca2ffc4cc6db9fc89.fritz.box~ $ sudo swupd diagnose
Passwort:
Diagnosing version 40620
Downloading missing manifests...
Checking for missing files
-> Missing file: /usr/share/icons/Adwaita/.icon-theme.cache
[100%]
Checking for corrupt files
[100%]
Checking for extraneous files
[100%]
Inspected 399498 files
1 file was missing
Use "swupd repair" to correct the problems in the system
Diagnose successful
Champion@clr-a454e39f8f34433ca2ffc4cc6db9fc89.fritz.box~ $ sudo swupd repair
[100%]
Validate downloaded files
[100%]
Starting download of remaining update content. This may take a while (3 files)...
[100%]
Adding any missing files
-> Missing file: /usr/share/icons/Adwaita/.icon-theme.cache -> fixed
[100%]
Repairing corrupt files
[100%]
Removing extraneous files
[100%]
1 file was missing
1 of 1 missing files were replaced
0 of 1 missing files were not replaced
External command: none
Repair successful
Champion@clr-a454e39f8f34433ca2ffc4cc6db9fc89.fritz.box~ $ sudo swupd clean
202 files removed
20,48 KB freed
Champion@clr-a454e39f8f34433ca2ffc4cc6db9fc89.fritz.box~ $ sudo localectl status
System Locale: LANG=de_DE.UTF-8
VC Keymap: de
X11 Layout: (unset)
