Hi all,
Just to let you know that the Clear Linux team is in the process of migrating from Pulse audio to Pipewire, which I’m sure will make at least @Aqua1ung very happy . Expect to see the switch over happen in the next few days.
Rgds,
Chris
Hi all,
Rgds,
Chris
Excellent news, thank you!
Will I have to undo the manual switch I did using this script?:
systemctl --user disable pulseaudio
systemctl --user enable pipewire{-pulse,}
systemctl --user enable wireplumber
How will the new Audio policy deal with this? Will it mess up my audio setup? ![]()
The pulseaudio unit will go away, the pipewire and wireplumber units will get the default global enable treatment so your enable/disable settings won’t be impacted.
