Hello anyone.
I hear about GNOME 46 release changelogs is Nautilus can mount Onedrive on it, but it need libmsgraph
(I guess) to enable this feature. I search it with swupd
, and libmsgraph
on os-utils-gui-dev
bundle. This bundle very bloated because I don’t want add other desktop (xfce4-desktop
is it dependency). My question is how to add Onedrive support on Nautilus without make my system bloater than now (my system very bloated because I need tecla
, and it on desktop-dev
bundle)? Thanks for your reply, and sorry my English.
Dependencies for libmsgraph :
glib2
glibc
gnome-online-accounts
json-glib
libgcc
libsoup3
You can install each with either swupd
or compile it yourself.
I think it is not supported officially with GNOME for Nautilus integration
How to get libsoup3
and libgcc
sudo swupd bundle-add devpkg-libsoup
sudo swupd bundle-add devpkg-gcc
I can’t get devpkg-gcc
on my system, like this
i@clr~ $ sudo swupd search-file libuhttpmock
Password:
[100%]
Searching for 'libuhttpmock'
Bundle devpkg-uhttpmock (36 MB to install)
/usr/lib64/pkgconfig/libuhttpmock-0.0.pc
/usr/lib64/libuhttpmock-0.0.so.0.2.3
/usr/include/libuhttpmock-0.0/uhttpmock/uhm.h
/usr/include/libuhttpmock-0.0/uhttpmock/uhm-version.h
/usr/include/libuhttpmock-0.0/uhttpmock/uhm-server.h
/usr/include/libuhttpmock-0.0/uhttpmock/uhm-resolver.h
You can use sudo swupd search-file
to search for exact matches in the clear repo. If your dependency not available you’ll have to build it yourself
if you’re still unable to compile it, you can export PKG_CONFIG_PATH
as an environment variable if you haven’t already.
echo export PKG_CONFIG_PATH='/usr/local/lib/pkgconfig:/usr/local/lib64/pkgconfig:/usr/lib64/pkgconfig:/usr/lib64/haswell/pkgconfig:/usr/lib/pkgconfig' >> ~/.bashrc
I still haven’t idea how to compile it
So, do you have any advice to me?
i think there’s different in the lib name, the required one is libuhttpmock-1.0. maybe this is the problem
