Hi,
so I created /etc/sudoers.d/visudo
(filename was chosen by visudo) with content:
username ALL=(ALL:ALL) ALL
…logged out & in but my application still complains about sudo permissions missing
any ideas ?
Hi,
any ideas ?
Check out this link - https://docs.01.org/clearlinux/latest/guides/maintenance/enable-user-space.html
Chris
adduser or useradd to add a new usersudo adduser username
Be sure to replace username with the user that you want to create. Also, note that to create a new user, you must also be a sudo user yourself.
passwd to update the new user’s passwordsudo passwd username
A strong password is highly recommended!
If one wants just to give permissions to some programm, he can add the following lines to the sudoers file:
%username ALL = NOPASSWD: /path/to/the/prog
