How to setup powerline
Install Powerline as user on Clearlinux
pip --user install powerline-status
copy config files to user .config
mkdir -p ~/.config/powerline
cp -a ~/.local/lib/python3.7/site-packages/powerline/config_files/* ~/.config/powerline/
create daemon
mkdir ~/.config/systemd/user/
cat << EOF > ~/.config/systemd/user/powerline.service
#powerline service
[Unit]
Description=powerline user service
[Service]
Type=oneshot
ExecStart=/home/${USER}/.local/bin/powerline-daemon -q
set .local/bin in path of user systemd
echo "PATH=$PATH:~/.local/bin" > ~/.config/environment.d/path.conf
#to update environment without logging out
`systemctl --user import-environment`
NB: if you are using gnome-wayland you have to do this
echo "PATH        OVERRIDE=${HOME}/bin:${HOME}/.local/bin:${PATH}" > ~/.pam_environment`
https://forum.manjaro.org/t/environment-variables-set-through-systemd-user-configuration-ignored/48247/6
Edit bashrc to automatically start powerline
   cat  << EOF >> ~/.bashrc
    PATH=$PATH:/home/${USER}/.local/bin
    if [ -f /home/${USER}/.local/lib/python3.7/site-packages/powerline/bindings/bash/powerline.sh ]; then
    source /home/${USER}/.local/lib/python3.7/site-packages/powerline/bindings/bash/powerline.sh
    fi
    EOF
systemctl --user enable powerline
log out then in
TODO: setup to use clears’ nice color scheme
https://superuser.com/questions/992210/how-to-set-environment-variables-for-a-gnome-wayland-session
This worked for me except that my python version folder was python3.8 instead of python3.7
