Downloading stacks on download packs. What can I do?
Hi @plomasteronnn - without knowing more about your situation and setup, it’s going to be a little difficult to help you.
What are you trying to do? How are you trying to do it? What hardware or VM do you have?
There’s lots of good information at Get started — Documentation for Clear Linux* project that should help you on your way.
Note - we have had some issues with the builds/swupd recently, so you may want to start over with the latest image.
Rgds,
Chris
Im trying to install clear linux on my pc .:
Inte i5 10400f
Nvidia 1050ti
16g memory
Ю́The installation gets to the point where the packs are downloaded, it’s already been loading for 2 hours
I’ll try and see if I can do an install with the latest ISO or IMG, but it’ll have to be tomorrow.
Problem solved. Thank you
i@clr~ $ sudo swupd repair
Password:
Diagnosing version 41560
Downloading missing manifests...
Checking for corrupt files
[100%]
Validate downloaded files
[100%]
Starting download of remaining update content. This may take a while (58 files)...
[100%]
Error: Curl - Communicating with server timed out - 'https://cdn.download.clearlinux.org/update/41530/files/5ab540fce9eaf4fdc3b9f4c6d469aefc87e3745176311e9200cc23692d646522.tar'
Error: Curl - Communicating with server timed out - 'https://cdn.download.clearlinux.org/update/41530/files/616ca92ff85d386e6d756d666a29ef3398e450ec6b71369b0a56aea4b611f55b.tar'
Error: Curl - Communicating with server timed out - 'https://cdn.download.clearlinux.org/update/41530/files/95deba40d0b2b7fbd2602ffeba0e55b39fe6ef92fcb9af22f6b0e4eeb4a46454.tar'
Error: Curl - Communicating with server timed out - 'https://cdn.download.clearlinux.org/update/41530/files/bce7a65361753707b9c08bdfa605d27801376526645c528cf633a22ad90c0b39.tar'
Error: Curl - Communicating with server timed out - 'https://cdn.download.clearlinux.org/update/41530/files/cc3e235caaf022dad9e06142aa68340eaf8b975ead0db0b1a885d84e78187e53.tar'
Error: Curl - Download error - (92) Stream error in the HTTP/2 framing layer
Curl - Reducing number of parallel downloads to 1
Curl - Starting download retry #1 for https://cdn.download.clearlinux.org/update/41530/files/cc3e235caaf022dad9e06142aa68340eaf8b975ead0db0b1a885d84e78187e53.tar
Curl - Resuming download for 'https://cdn.download.clearlinux.org/update/41530/files/cc3e235caaf022dad9e06142aa68340eaf8b975ead0db0b1a885d84e78187e53.tar'
Curl - Starting download retry #1 for https://cdn.download.clearlinux.org/update/41530/files/bce7a65361753707b9c08bdfa605d27801376526645c528cf633a22ad90c0b39.tar
Curl - Resuming download for 'https://cdn.download.clearlinux.org/update/41530/files/bce7a65361753707b9c08bdfa605d27801376526645c528cf633a22ad90c0b39.tar'
Curl - Starting download retry #1 for https://cdn.download.clearlinux.org/update/41530/files/95deba40d0b2b7fbd2602ffeba0e55b39fe6ef92fcb9af22f6b0e4eeb4a46454.tar
Curl - Resuming download for 'https://cdn.download.clearlinux.org/update/41530/files/95deba40d0b2b7fbd2602ffeba0e55b39fe6ef92fcb9af22f6b0e4eeb4a46454.tar'
Curl - Starting download retry #1 for https://cdn.download.clearlinux.org/update/41530/files/616ca92ff85d386e6d756d666a29ef3398e450ec6b71369b0a56aea4b611f55b.tar
Curl - Resuming download for 'https://cdn.download.clearlinux.org/update/41530/files/616ca92ff85d386e6d756d666a29ef3398e450ec6b71369b0a56aea4b611f55b.tar'
Curl - Starting download retry #1 for https://cdn.download.clearlinux.org/update/41530/files/5f2e39334298f72d10827d7b08037610c6471fd37268fd4fce519a983caa483e.tar
Curl - Resuming download for 'https://cdn.download.clearlinux.org/update/41530/files/5f2e39334298f72d10827d7b08037610c6471fd37268fd4fce519a983caa483e.tar'
Curl - Starting download retry #1 for https://cdn.download.clearlinux.org/update/41530/files/5ab540fce9eaf4fdc3b9f4c6d469aefc87e3745176311e9200cc23692d646522.tar
Curl - Resuming download for 'https://cdn.download.clearlinux.org/update/41530/files/5ab540fce9eaf4fdc3b9f4c6d469aefc87e3745176311e9200cc23692d646522.tar'
Curl - Starting download retry #2 for https://cdn.download.clearlinux.org/update/41530/files/5f2e39334298f72d10827d7b08037610c6471fd37268fd4fce519a983caa483e.tar
Error: Curl - Communicating with server timed out - 'https://cdn.download.clearlinux.org/update/41530/files/5f2e39334298f72d10827d7b08037610c6471fd37268fd4fce519a983caa483e.tar'
Curl - Starting download retry #2 for https://cdn.download.clearlinux.org/update/41530/files/5ab540fce9eaf4fdc3b9f4c6d469aefc87e3745176311e9200cc23692d646522.tar
Curl - Starting download retry #3 for https://cdn.download.clearlinux.org/update/41530/files/5f2e39334298f72d10827d7b08037610c6471fd37268fd4fce519a983caa483e.tar
Error: Curl - Partial file downloaded from 'https://cdn.download.clearlinux.org/update/41530/files/5f2e39334298f72d10827d7b08037610c6471fd37268fd4fce519a983caa483e.tar'
Error: Unable to download necessary files for this OS release
Repair did not fully succeed
I’m not sure how related this is though
i hate it when this happens. my workaround is using lazy mirror with apt-cacher-ng on debian(container or other pc will work)
Very hard Clear linux for me! Sorry Need More guilds!
We do have a lot of guides at Guides — Documentation for Clear Linux* project , but yes, the learning curve is quite steep if you’re not an experienced Linux user. This distribution is aimed at developers.
Same problem was occurring, but it got fixed on its own.
