Hi, has anyone tried to compile latest kernel for testing in Clear Linux with patches and built in wiregaurd?
Update:
Tried to build myself, had to disable patch 0116 and 1001(wg) and still no luck with
error:
+ mkdir -p cpiofile/usr/lib/modules/5.6-926.native/kernel/drivers/hid
+ cp /builddir/build/BUILDROOT/linux-af-5.6-926.x86_64/usr/lib/modules/5.6-926.native/kernel/drivers/input/serio/i8042.ko cpiofile/usr/lib/modules/5.6-926.native/kernel/drivers/input/serio
cp: cannot stat '/builddir/build/BUILDROOT/linux-af-5.6-926.x86_64/usr/lib/modules/5.6-926.native/kernel/drivers/input/serio/i8042.ko': No such file or directory
error: Bad exit status from /var/tmp/rpm-tmp.bA31Ys (%install)
RPM build errors:
Finish: rpmbuild linux-af-5.6-926.src.rpm
Finish: build phase for linux-af-5.6-926.src.rpm
ERROR: Exception(results/linux-af-5.6-926.src.rpm) Config(clear) 22 minutes 0 seconds
INFO: Results and/or logs in: results/
ERROR: Command failed:
# /usr/bin/systemd-nspawn -q -M ee7f90f2f5b44a03bd8abf38f0666145 -D /var/lib/mock/clear-linux/root -a --capability=cap_ipc_lock --console=pipe --bind=/tmp/mock-resolv.ifw573xa:/etc/resolv.conf --setenv=TERM=vt100 --setenv=SHELL=/bin/bash --setenv=HOME=/builddir --setenv=HOSTNAME=mock --setenv=PATH=/usr/bin:/bin:/usr/sbin:/sbin --setenv=PROMPT_COMMAND=printf "\033]0;<mock-chroot>\007" --setenv=PS1=<mock-chroot> \s-\v\$ --setenv=LANG=en_US.UTF-8 -u mockbuild bash --login -c /usr/bin/rpmbuild -bb --target x86_64 --nodeps /builddir/build/SPECS/linux.spec
make: *** [../common/Makefile.common:88: build] Error 1
make build 8589,67s user 1081,48s system 713% cpu 22:36,23 total
