Dear All
What is the best way to launch a Script on the login ?
I have some rclone mounts ie some .sh files that I want to start when the machine logs in
Thanks
Dear All
Thanks
Do you mean login of a user, or when the system boots?
You can do either, but, the methods are vastly different based on what you actually want.
Lovely !
I was thinking as a user ?
But both would be educational
Dear Auke,
Am I right by making a profile.d folder and placing the scripts in there ? For scripts when the user logs in ?
They are called systemd units.
You can create user systemd unit using
mkdir -p ~/.config/systemd/user/
here there is an example of a unit:
$ cat ~/.config/systemd/user/example1.service
[Unit]
Description=Example description
[Service]
Type=oneshot
ExecStart=/full/path/to/your/bash/script
[Install]
WantedBy=default.target
Then enable it to run when you login
systemctl --user enable example.service
if you want to execute a user script when the system boots then
sudo mkdir -p /etc/systemd/system/
and the service unit is
$ cat /etc/systemd/system/example2.service
[Unit]
Description=Example 2
[Service]
Type=oneshot
User=YOUR_USER
WorkingDirectory=/home/YOUR_USER
ExecStart=/full/path/to/your/script
[Install]
WantedBy=multi-user.target
to enable run:
sudo systemctl enable example2.service
you can find more information searching for systemd units.
Or the traditional way
adding your scripts to ~/.bashrc
Perfect !
Thank you guys for confirming nice and easy to follow
