On emacs runtime, i got a warning buffer spamming me message similar to:
gcc: fatal error: cannot execute ‘as’: execvp: No such file or directory
this problem got easily solved by installing binutils
swupd bundle-add binutils
next, when i open M-x dired
i get messages:
⛔ Warning (comp): libgccjit.so: error: error invoking gcc driver
⛔ Warning (comp): /usr/share/emacs/29.1/lisp/emacs-lisp/cl-lib.el.gz: Error: Internal native compiler error
finally, not related to emacs, in terminal swupd
command has broken tab completion for arguments
swupd <tab> => _init_completion: command not found
P.S. I’m confused, if emacs is installed by default, i don’t understand why not install all its run-time dependencies also.
