Hello, I would like to get directions on how installing nvidia-libs support for wine , in order to have cuda support on windows only software
I installed the nvidia drivers from github marioroy/nvidia-driver-on-clear-linux
I did my best trying to find the right bundles , but the compilation always failed, showing some errors in meson, but I suspect mostly related to MINGW . I already installed all the bundles I could think about, specifically those for compiling pyenv : devpkg-ncurses sqlite devpkg-openssl tcl-basic devpkg-readline devpkg-bzip2 devpkg-sqlite-autoconf devpkg-libffi devpkg-xz user-basic-dev c-basic-mingw wineand who knows what, but onestly no luck.
Right now I’m back to arch, so I cannot reproduce errors-logs ,but I would like to be back on clearlinux if this can be fixed. Also, I might be missing something very obvious, but is there a way to search for bundles ? So far, beside google, the best luck I had was browsing here: clr-bundles/bundles at master · clearlinux/clr-bundles · GitHub
thank You so much, swupd search-file sounds really good, and I didn’t know dnf was installable … If I recall correctly, troubles were coming while compiling the libs, not from the lack of libwinecrt0.a . I also think that nvidia cuda patches were removed from wine-staging a long while ago, so, even installing wine-staging wouldn’t give access to cuda. Right now i’m on arch, using wine 9.3-1 (normal wine), and after installing GitHub - SveSop/nvidia-libs: Collection of nVidia libraries for use with Wine or Steam Proton. cuda works well
I think I may have stumbled across your issue stderr: x86_64-w64-mingw32-g++: error: unrecognized command line option '-mrelax-cmpxchg-loop'
Removing it from the CFLAGS gives this error error: 'mutex' in namespace 'std' does not name a type
The fix for this is as of dxvk: troubleshooting is to have posix threading support enabled in the cross compiler. Looking at mingw-gcc it’s built with --enable-threads=win32 instead you need one built with --enable-threads=posix
building tips: gcc_crosscompile_setup_help
Thank You! I was just playing right now on a new cl install, and I was stumbling on this issue, so I was going to post the log file, but You’ve been quicker So, if I understand correctly, i would have to recompile the c-basic-mingw bundle myself enabling the --enable-threads=posix flag? How can I install such self compiled bundle then? This is honestly going beyond my limited knowledge …
I post the log anyway… who knows… it might help
Build started at 2024-03-13T09:37:30.114146
Main binary: /usr/bin/python3
Build Options: -Denable_tests=true -Dprefix=/home/kurageart/nvidia-libs/compilato/nvidia-libs-nvlibs -Dlibdir=lib64 -Dbuildtype=release -Dstrip=True --cross-file=/home/kurageart/nvidia-libs/dxvk-nvapi/build-win64.txt
Python system: Linux
The Meson build system
Version: 1.3.2
Source dir: /home/kurageart/nvidia-libs/dxvk-nvapi
Build dir: /home/kurageart/nvidia-libs/compilato/nvidia-libs-nvlibs/build.64
Build type: cross build
Project name: dxvk-nvapi
Project version: v0.6.4
Detecting compiler via: `x86_64-w64-mingw32-g++ --version` -> 0
stdout:
x86_64-w64-mingw32-g++ (Clear Linux OS for Intel Architecture) 9.2.1 20191029 gcc-9-branch@277549
Copyright (C) 2019 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
Running command: x86_64-w64-mingw32-g++ -E -dM -
Detecting linker via: `x86_64-w64-mingw32-g++ -Wl,--version -static -static-libgcc -static-libstdc++ -g -O3 -feliminate-unused-debug-types -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -Wformat -Wformat-security -m64 -fasynchronous-unwind-tables -Wp,-D_REENTRANT -ftree-loop-distribute-patterns -Wl,-z,now -Wl,-z,relro -fno-semantic-interposition -ffat-lto-objects -fno-trapping-math -Wl,-sort-common -Wl,--enable-new-dtags -mrelax-cmpxchg-loop -ffunction-sections -fvisibility-inlines-hidden -Wl,--enable-new-dtags -std=gnu++17` -> 1
stderr:
meson.build:1:0: ERROR: Unable to detect linker for compiler `x86_64-w64-mingw32-g++ -Wl,--version -static -static-libgcc -static-libstdc++ -g -O3 -feliminate-unused-debug-types -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -Wformat -Wformat-security -m64 -fasynchronous-unwind-tables -Wp,-D_REENTRANT -ftree-loop-distribute-patterns -Wl,-z,now -Wl,-z,relro -fno-semantic-interposition -ffat-lto-objects -fno-trapping-math -Wl,-sort-common -Wl,--enable-new-dtags -mrelax-cmpxchg-loop -ffunction-sections -fvisibility-inlines-hidden -Wl,--enable-new-dtags -std=gnu++17`
stdout:
Ok … for those concerning, instead of going trough the “compile” way (that is not going to work anyway), on Releases · SveSop/nvidia-libs · GitHub You can get the last release and just install on your WINEPREFIX
