I noticed this error when booting to graphical target:
/usr/libexec/gnome-session-check-accelerated-gl-helper: error while loading shared libraries: libglapi.so.0: cannot open shared object file: No such file or directory
And sure enough, running sudo find / -name "libglapi*" shows it doesn’t exist. It finds nothing.
I have attempted full picky system repair. It doesn’t appear.
Build 43220, kernel 6.13.9. I cannot use any later build because it switches to kernel 6.14 which wreaks havoc on my CPU for the first few versions of 6.14, and then switches to gcc 15 which wreaks havoc on the NVIDIA drivers.
Why would this happen?
May 10 02:31:52 clear /usr/libexec/gdm-x-session[59325]: (--) NVIDIA(GPU-0): Philips PHL 279P1 (DFP-1): connected
May 10 02:31:52 clear /usr/libexec/gdm-x-session[59325]: (--) NVIDIA(GPU-0): Philips PHL 279P1 (DFP-1): Internal DisplayPort
May 10 02:31:52 clear /usr/libexec/gdm-x-session[59325]: (--) NVIDIA(GPU-0): Philips PHL 279P1 (DFP-1): 2670.0 MHz maximum pixel clock
May 10 02:31:52 clear systemd[59313]: Created slice session.slice.
May 10 02:31:52 clear systemd[59313]: Starting dbus.service...
May 10 02:31:52 clear systemd[59313]: Started dbus.service.
May 10 02:31:52 clear dbus-daemon[59351]: [session uid=311 pid=59351] Successfully activated service 'org.freedesktop.systemd1'
May 10 02:31:52 clear /usr/libexec/gdm-x-session[59354]: dbus-daemon[59354]: [session uid=311 pid=59354] Activating service name='org.a11y.Bus' requested by ':1.0' (uid=311 pid=59360 comm="/usr/libexec/gnome-session-check-accelerated")
May 10 02:31:52 clear /usr/libexec/gdm-x-session[59354]: dbus-daemon[59354]: [session uid=311 pid=59354] Successfully activated service 'org.a11y.Bus'
May 10 02:31:52 clear gnome-session[59369]: /usr/libexec/gnome-session-check-accelerated-gl-helper: error while loading shared libraries: libglapi.so.0: cannot open shared object file: No such file or directory
May 10 02:31:52 clear gnome-session[59360]: gnome-session-check-accelerated: GL Helper exited with code 32512
May 10 02:31:52 clear gnome-session[59370]: /usr/libexec/gnome-session-check-accelerated-gles-helper: error while loading shared libraries: libglapi.so.0: cannot open shared object file: No such file or directory
May 10 02:31:52 clear gnome-session[59360]: gnome-session-check-accelerated: GLES Helper exited with code 32512
May 10 02:31:52 clear /usr/libexec/gdm-x-session[59368]: dbus-daemon[59368]: Activating service name='org.a11y.atspi.Registry' requested by ':1.1' (uid=311 pid=59371 comm="/usr/libexec/gnome-session-check-accelerated")
May 10 02:31:52 clear /usr/libexec/gdm-x-session[59368]: dbus-daemon[59368]: Successfully activated service 'org.a11y.atspi.Registry'
May 10 02:31:52 clear /usr/libexec/gdm-x-session[59373]: SpiRegistry daemon is running with well-known name - org.a11y.atspi.Registry
May 10 02:31:57 clear gnome-session[59378]: /usr/libexec/gnome-session-check-accelerated-gl-helper: error while loading shared libraries: libglapi.so.0: cannot open shared object file: No such file or directory
May 10 02:31:57 clear gnome-session[59371]: gnome-session-check-accelerated: GL Helper exited with code 32512
May 10 02:31:57 clear gnome-session[59379]: /usr/libexec/gnome-session-check-accelerated-gles-helper: error while loading shared libraries: libglapi.so.0: cannot open shared object file: No such file or directory
May 10 02:31:57 clear gnome-session[59371]: gnome-session-check-accelerated: GLES Helper exited with code 32512
May 10 02:31:57 clear gnome-session[59355]: gnome-session-binary[59355]: WARNING: software acceleration check failed: Child process exited with code 1
May 10 02:31:57 clear gnome-session-binary[59355]: WARNING: software acceleration check failed: Child process exited with code 1
