VLC could not decode the format "mp4a" (MPEG AAC Audio) Does not fully address my inquiries.
FIrst: Flatpak vlc installs at nearly 2GB and renders avc1 and aac audio, so this is not the issue… I want to eliminate flatpack and add codecs to use Clear Linux vlc.
Vlc installed with bundle-add, and apparently codecs are not supported for avc1 and aac audio due to patent issues, got that.
Additionally ffmpeg was installed from source.
Went to 3rd party site Clear Fraction and installed codec pack but Clear Linux version of vlc crashes when attempting to play .mp4 with avc1 and aac audio.
Clear Fraction install added following PATH info:
sudo swupd 3rd-party add clearfraction https://clearfraction.vercel.app/update
sudo mkdir -p /etc/environment.d /etc/profile.d
sudo tee -a /etc/environment.d/10-cf.conf << EOF
PATH=/usr/bin/haswell:/usr/bin:/usr/local/bin:/opt/3rd-party/bundles/clearfraction/bin:/opt/3rd-party/bundles/clearfraction/usr/bin:/opt/3rd-party/bundles/clearfraction/usr/local/bin
LD_LIBRARY_PATH=/usr/lib64:/opt/3rd-party/bundles/clearfraction/usr/lib64:/opt/3rd-party/bundles/clearfraction/usr/local/lib64
XDG_DATA_DIRS=/usr/share:/usr/local/share:/opt/3rd-party/bundles/clearfraction/usr/share:/opt/3rd-party/bundles/clearfraction/usr/local/share:/home/$USER/.local/share/flatpak/exports/share:/home/$USER/.local/share/flatpak/exports/share
XDG_CONFIG_DIRS=/usr/share/xdg:/etc/xdg:/opt/3rd-party/bundles/clearfraction/usr/share/xdg:/opt/3rd-party/bundles/clearfraction/etc/xdg
FONTCONFIG_PATH=/usr/share/defaults/fonts
GST_PLUGIN_PATH_1_0=/usr/lib64/gstreamer-1.0:/opt/3rd-party/bundles/clearfraction/usr/lib64/gstreamer-1.0
EOF
sudo tee -a /etc/profile.d/10-cf.sh << ‘EOF’
[[ ! ${PATH} =~ “/opt/3rd-party/bundles/clearfraction/bin” ]] &&
PATH=$PATH:/opt/3rd-party/bundles/clearfraction/bin:/opt/3rd-party/bundles/clearfraction/usr/bin:/opt/3rd-party/bundles/clearfraction/usr/local/bin
[[ ! ${LD_LIBRARY_PATH} =~ “/opt/3rd-party/bundles/clearfraction/usr/lib64” ]] &&
LD_LIBRARY_PATH=/usr/lib64:/opt/3rd-party/bundles/clearfraction/usr/lib64:/opt/3rd-party/bundles/clearfraction/usr/local/lib64${LD_LIBRARY_PATH:+:$LD_LIBRARY_PATH}
[[ ! ${XDG_DATA_DIRS} =~ “/opt/3rd-party/bundles/clearfraction/usr/share” ]] &&
XDG_DATA_DIRS=${XDG_DATA_DIRS:-/usr/local/share/:/usr/share/}:/opt/3rd-party/bundles/clearfraction/usr/share/:/opt/3rd-party/bundles/clearfraction/usr/local/share/
[[ ! ${XDG_CONFIG_DIRS} =~ “/opt/3rd-party/bundles/clearfraction/usr/share/xdg” ]] &&
XDG_CONFIG_DIRS=${XDG_CONFIG_DIRS:-/usr/share/xdg:/etc/xdg}:/opt/3rd-party/bundles/clearfraction/usr/share/xdg:/opt/3rd-party/bundles/clearfraction/etc/xdg
[[ ! ${FONTCONFIG_PATH} =~ “/usr/share/defaults/fonts” ]] &&
FONTCONFIG_PATH=/usr/share/defaults/fonts${FONTCONFIG_PATH:+:$FONTCONFIG_PATH}
[[ ! ${GST_PLUGIN_PATH_1_0} =~ “/opt/3rd-party/bundles/clearfraction/usr/lib64/gstreamer-1.0” ]] &&
GST_PLUGIN_PATH_1_0=${GST_PLUGIN_PATH_1_0:-/usr/lib64/gstreamer-1.0}:/opt/3rd-party/bundles/clearfraction/usr/lib64/gstreamer-1.0
EOF
Am I missing something?
Can the stock Clear Linux vlc install be made to render .mp4 avc1 video and aac audio?
Am I missing configuration changes necessary?
Any help appreciated.
Thank you.
