I’m using nginx-mainline and would like to be able to use the auth_request directive. However nginx-mainline is missing this module. Would it be possible to add a more complete list of modules that are compiled into nginx-mainline. I’ve pasted below a list of modules that are compiled into the nginx docker container but are missing from the nginx-mainline Clear Linux bundle. It would be good to add all of the following, but I could really use at least the auth_request module.
Yes! We can totally add these. Can you help, and give me the upstream project URL’s for these? Hunting down the actual location of these projects is a pain, since there doesn’t seem to be an official resource for these modules like PECL, pypy and CPAN has…
I believe these are modules that can be added simply by adding the corresponding “—with…” options to the configure command. The Nginx docker container is built with the following configure arguments. Note that these may not all be appropriate for the Clear Linux build, but the with-XXX-module arguments are the ones that should be added.
Ahhh no! this is not how we build nginx. We build nginx modules out of tree and the docker container build you are looking at builds them in-tree.
The sources for these modules are not part of the nginx sources. I therefore need to still know the github/git project URL’s for each and every one of them, because … well, that’s how building starts
If you download https://github.com/nginx/nginx/archive/release-1.17.8.tar.gz, and look at the contents, you will find sources for all of those modules. So I believe these are all part of the nginx sources. I do not believe that these modules can be compiled as dynamic modules. They need to be compiled into nginx. This means this is a change to the nginx-mainline bundle, not the nginx-mainline-extras bundle.
