Assistance building Gamescope from source
Ive been trying to build Gamescope for a few days now and keep running into issues.
As per the instructions on Valve’s Github Ive run the following commands
EDITED (I forgot to mention I ran this command without errors too):
git submodule update --init
meson build/
and received the following output
pastebin
this is after using a number of “swupd search” to try and find missing dependencies as well as cloning and building hwdata.
As the output from that doesn’t seem to have any catastrophic errors I then moved on to the next lines
ninja -C build/
which gave a lot of errors, mostly seeming to take issue with the c++ compiler
pastebin part 1
pastebin part 2
It now appears that I am unable to continue any further with building this, so would like to ask for some help from the community.
Any suggestions for next steps to take? have I missed something obvious in my newness?
Thanks for reading
Got stuck in the same place as you are in. Tried checking out some older versions, no dice
